December 31, 2023 at 1:16 am
Swan Htet
SubscriberHi there,Â
Could you please help me with my Ansys program?Â
I am having this error message whenever I tried to launch workbench 2023 R2"An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.Â--- System.DllNotFoundException: Unable to load DLL 'SceneGraphChart.Components.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)Â Â at Ans.SceneGraphChart.Engine.Ans_SceneGraph_Bootup(Object p_iConfiguration, Object p_iErrorHandler)Â Â at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)Â Â at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)Â Â at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)Â Â at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)"ÂI am running ansys on window 11, in parallel with MacOS with M2 chip. -
March 6, 2024 at 4:46 pm
Ashish Khemka
Forum ModeratorHi,
Please see if this post helps you: Error with workbench SceneGraphChart (ansys.com)
Ashish Khemka
- The topic ‘Workbench cannot be launched!’ is closed to new replies.
1311
