August 4, 2022 at 12:30 pm
wdavid
SubscriberI've recently come back to ANSYS for a new project, but am unable to open the software. Some components open fine, but the Workbench and Mechanical crash after reaching 'Initializing Project' on the loading screen. I've tried restarting and re-installing but am still having the same issue.
In the Windows Event viewer I'm getting this application error which I'm told suggests a corrupted file, but I don't see how this could be the case and still persist after re-installing?
Any thoughts welcome, am at a loss as to what I can try
August 9, 2022 at 12:48 am
George Karnos
Ansys EmployeeClose all ANSYS programs.
Open Windows File Explorer and then type in the following in the address line:%APPDATA%\Ansys\v222
hit enter
You should see a directory named:Â
Rename this directory to:Â v222.old
Now try to run.
August 9, 2022 at 11:10 am
wdavid
SubscriberHi George,
Thanks for the response and help. What directory am I meant to be renaming, sorry? I think you missed it off
August 9, 2022 at 12:32 pm
George Karnos
Ansys Employee@wdavid,
My apologies for the typo!
Go to:
%APPDATA%\Ansys\
hit enter
You should see a directory named: (V2## depeding on version installed)
If version 2022 R2:
v222
August 9, 2022 at 2:25 pm
wdavid
SubscriberThanks. I did this and, it created a new directory v222. However, the problem is still not solved, still crashes on the 'initializing project' screen
August 11, 2022 at 12:50 pm
wdavid
SubscriberProblem solved - My anitvirus wasn't letting it through
- The topic ‘Workbench and Mechanical crash on startup’ is closed to new replies.
6515
