Windkessel Model Implementation_ANSYS Fluent 2022 R2
    • AMAR SHRIVASTAVA
      I have loaded the Windkessel extension through Workbench but it is not showing anywhere in Fluent 2022 R2 version. I am trying to run the straight pipe tutorial example but I am not able to implement WK3. Any kind of help in the right direction would do. Thank you
      Where are you loading what from? The Ansys ACT was last updated for around R17 so may not work well.
    • AMAR SHRIVASTAVA
      I was trying to load the Windkessel extension (17.x) in ANSYS Fluent 2022 R2...I am not able to implement it as outlet boundary condition in Fluent tutorial example..Should I install ANSYS 17 version? Please guide...from where can I install ANSYS 17 version ?
      There isn't a Student build of R17, and it's not worth trying to get the "full" version off the Portal given it's age. I'm not aware of a revised version at present.
  • The topic ‘Windkessel Model Implementation_ANSYS Fluent 2022 R2’ is closed to new replies.
