Why my contact is not working?
    • Munchy99
      Dear All,
      I am working on my FYP which is a 4D printed Microgripper, my model is in static structural analysis. I had tried to configure the contact in frictional, frictionless and others, but the tips of the gripper still penetrated towards each other. As for other parts that were bonded, the contact settings seems to be working fine.
      Does anyone has any idea how to solve this? ?
      In the Details window for the Frictional Contact is a line called Pinball Radius. You need to enter a value of the radius that is larger than the distance between the two surfaces. The pinball is shown as the red sphere. The red sphere has to reach the blue surface for the contact to be included in the simulation.
    • Munchy99
      Thanks for your reply, I have set the larger radius, but the contact is still not working, attached is the screenshot.
      Double the size of the pinball radius.
      Under the Connections folder, insert a Contact Tool, then Generate Initial Contact Status and see if the contact lists as Near Open. That means it will be included in the simulation.
      If you make the Pinball radius small, and Generate Initial Contact Status again, it will be Far Open. That means it will not be included in the simulation.
    • Munchy99
      Still not working
      Under the Analysis Settings, turn on Large Deflection
    • Munchy99
      Thanks for your explanation but no matter small or big, I still getting far open.
      Try removing the short horizontal surface at the top from the contact and target sides of the definition, keep just the single large surface on each side.
      If that doesn't fix it, you need to change some settings in the Details window that are cut off in your image.
    • Munchy99
      I have changed it to 1 side, still doesn't fix. Attached is the full details.
      I see now that you have a surface body, and are trying to make the edges contact. What are the choices under Edge Contact Type?
      Do you need this model to be in 3D? I suggest you solve it as a 2D model, then the contact would work.
      To build a 2D model, you have to start fresh in the Geometry editor, and rotate the surfaces into the XY plane.
      Start a new Static Structural model, and in Workbench, click the Geometry tab and in the Properties window, set the Analysis Type to 2D.
      After you open the model in Mechanical, you set the type of 2D analysis to Plane Stress for thin parts in the z-direction or Plane Strain for very thick parts.
    • Munchy99
      I actually tried to set the face contact first in the 3D model, but I found some guy saying that converting to mid-surface 2D would work.
      Now that I rotated the sketch and the Mechanical cannot read my model.
      (I drew my 3D model in Solidworks and imported as parasolid)
      But I would prefer it as a 3D model.
      Are the surfaces at Z=0?
      Please put the Parasolid file into an archive .7z or .rar and attach it to your reply.
    • Munchy99
      My bad, the surface are not at z=0, I tried to shift it, but it is still at z = 0.001mm. I have attached the file.
      I am not familiar with Design Modeler
      You must improve your geometry skills if you want to be successful with simulation. I repaired the alignment and created the surfaces that are needed for a 2D analysis.
    • Munchy99
      Thank you very much!!! I will look into tutorials for drawing in design modeler/ space claim, may I know how u repair the alignment?
      In SpaceClaim, I put the three components into a new component. Created a plane on the XY plane. On the Assembly Tab, I used the Tangent button and the Align button.
      The design is to clamp an object. It would be a more realistic model if you put an object, such as a circle, in the center for it to clamp against. The circle could be the Target, the two flat faces of the clamp can be the Contact side of a Frictional Contact.
    • Munchy99
      Alright, I will try it. I also thought about putting the circle to analyze force. Thanks a lot for your help sir.
Viewing 16 reply threads
  • The topic ‘Why my contact is not working?’ is closed to new replies.
