January 6, 2025 at 8:07 amMagnusSubscriber
I received this email after our supplier provided us with a licence:An administrator from Johansen Monumenthuggeri has added you to their organization and assigned an Ansys Discovery subscription to you. The email address associated with your account is mj@johansenmonument.no.
To get started, sign in and follow the instructions to get to the Discovery Forum. From there download and install Ansys Discovery. You can then launch the application and sign in using your Ansys Account.
For technical support, please reach out to your usual Ansys support representative.
Sincerely,
The Ansys Discovery TeamMy question is; Where do we download the software??Â
Thanks and Best Regards,Â
Magnus -
January 6, 2025 at 8:47 amHarshvardhanAnsys Employee
Ansys software can be downloaded from the Ansys Customer Portal.
Home Page - Ansys Customer Portal
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
January 6, 2025 at 10:14 amDevendra BadgujarForum Moderator
Hi,Â
You can also download Ansys Discovery products from here Discovery Downloads | Ansys Knowledge
DevendraÂ
- Unable to attach geometry 2024 R2
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
1602
613
599
591
366
