March 12, 2026 at 6:59 am
FAQParticipantAnsys Known Issues and Limitations PDF can be downloaded from here: Release Notes 26.1*
Download Center
Ansys Discovery products are available to download from the Customer Portal at the link below. The current version is Release 2026 R1, released 12 March 2026.
The primary download packages are:
ANSYS DISCOVERY (12.20 GB)
Includes:
- Ansys Discovery
- Ansys Geometry Interfaces
- Ansys License Manager*
ANSYS SPACECLAIM (2.10GB)
Includes:
- Ansys SpaceClaim
2026 R1 SERVICE PACK 1 (14.90 GB)
Includes latest enhancements for:
- Ansys Discovery
- Ansys SpaceClaim
Apply after installing the base release.
* These packages support both network and we based licensing. Service Pack documentation can be found in the same downloads centre.
Software packages for previous versions of Ansys Discovery and Ansys SpaceClaim products are available to download as well.
Documents
Attached here is the Discovery Installation Guide, covering topics from Installation Prerequisites to Product Licensing as well as a guide for the installation steps.
For additional information, please also refer to the Known Issues and Limitations for this release, from the link provided above.
Add-on Packages
The Customer Portal also provides add-on which further enhance Ansys Discovery:
- For Autodesk Fusion users, an addin is provided for import of simulation projects from Autodesk Fusion 360 Simulation or Generative Design outcomes.
- Sample Addins contain several example add-ins to help you get started customizing Discovery to further enhance it for your simulation needs.
Note: *The Release Notes 26.1 link will require users to login and only licensed users will be able to access it.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
