December 13, 2024 at 4:57 pm
December 16, 2024 at 10:20 amRobForum Moderator
SIGSEV usually means you're trying to call a value that doesn't exist. The code loads so it's gramatically correct, so check for UDS/UDM/memory usage.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
802
599
591
366
