July 6, 2021 at 10:29 ameugenzilioSubscriber
I scoured the web for information on what techniques are used by the software and what I have so far is:
ANSYS Discovery - Explore
- voxel-based
- Cartesian
- FVM
- LES
ANSYS Discovery - Refine
- Lattice-Boltzmann
- LBM-RANS or LBM-LES
I would like to know more about the two simulation modes in order to understand what class of methods I am using.
July 12, 2021 at 1:08 pmNaresh PatreAnsys EmployeeHello eugenzilio
Please check out below article on simulation technology used in Ansys Discovery that is posted on Ansys Discovery forum
https://discoveryforum.ansys.com/t/y71xrh/what-simulation-technology-does-discovery-live-use
July 12, 2021 at 1:26 pmeugenzilioSubscriberThank you. I've already seen this post but it talks about ANSYS Discovery Live. From my understanding Discovery - Explore and Discovery Live are the same. Nevertheless, I would like to know more, such as the type of discretisation scheme and turbulence model. In addition, there is Discovery - Refine, which seems to be quite different to the other two.
July 12, 2021 at 4:16 pmAmine Ben Hadj AliAnsys EmployeeRefine is using CPU based solver and requires a mesh. Regarding Explore: nothing else can be shared in addition to what we have posted on the discovery forum.
July 13, 2021 at 8:22 ameugenzilioSubscriberThank you for your response.
July 13, 2021 at 11:56 amAmine Ben Hadj AliAnsys EmployeeWelcome!
Viewing 5 reply threads- The topic ‘What simulation technology does ANSYS Discovery use?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
Top Contributors-
1762
635
599
591
366
