February 21, 2023 at 8:55 am
pavankonchada123
SubscriberHi Ansys Team,
Can you please through some light on the below warning
Warning: injection: injection-0: zero particle mass, cannot conserve injection mass flow rate
February 21, 2023 at 1:41 pm
Forum ModeratorCheck the injection. There was a change a few versions back so you need a small mass even if you don't have interaction with continuous phase switched on. 1e-20 kg/s is sufficient.Â
- The topic ‘Warning in DPM’ is closed to new replies.
1890
1419
1304
