Warning: Failed to correct face handedness
    • fa-ri
      hello
      I'm working on flow past a 4-rotor drone.
      I meshed the geometry using curvature size function and I have a tetrahedrons mesh method.
      I initialized the simulation and used mesh motion for each rotating volume.
      how can I fix this warning?
      I would be really grateful if anyone could help me
      Thank you
      With regards
    • Keyur Kanade
      Did you check the mesh before starting simulation? Did it pass the check?
      When you created mesh, what was the quality. Please check orthogonal quality of the mesh. The min ortho must be more than 0.1.
      Also did you use non conformal interface of sliding mesh? Did you define the axis of rotation correctly in Fluent?
      Please have a look at following for sliding mesh.
      https://www.youtube.com/watch?v=93hxZuIA75I
      Keyur
    • Keyur Kanade
      You may also want to look at following post.
      /forum/forums/topic/how-can-i-locate-and-fix-left-handed-cel/
      Keyur
    • fa-ri
      Thank you for your response.
      I checked the orthogonal quality of the mesh. The min was 0.2004.and its non-conformal.
      I checked the rotating axis.
      during of flowing the tutorial I see the following errors:
      I ignored the note and saw this one during processing
      how can I fix this problem?
      Thank you
      With regards
    • Keyur Kanade
      You can ignore the first note of creating empty surfaces.
      For second error - can you please check if you can process it using serial mode first.
      Are you using any UDF? Are there any solid zone? Please cross check your boundary conditions. Please check boundary types.
      Keyur
    • Shahid Haqim
      I am facing the same problem. Hoping someone would guide to resolve this issue. The max skewness is below 0.9 and min ortho quality is above 0.1
Viewing 5 reply threads
  • The topic ‘Warning: Failed to correct face handedness’ is closed to new replies.
