January 20, 2025 at 10:29 pm
cheng-wl
SubscriberI am running a simulation for internal flow to try matching the experimental data. However, I am confused about the wall surface condition setting. I try to set the roughness height using data from the fluid textbook. That tends to give a mass flow rate too small compare to experiments. I reduced it to zero and mass flow rate increased.
Now, it comes to adjusting wall roughness constant. When I increased it, the mass flow rate decreases, so I reduced that from the default value of 0.5. I can then matched my experimental data. However, when I read from the manual, it says 0.5 is the value to be used for a surface with uniform grain. Otherwise, the value should be 0.5 - 1.0. So, can a value 0 - 0.5 be used as the roughness constant? Does that physically mean anything?
January 27, 2025 at 3:37 pm
Federico
Ansys EmployeeThere are several resources in our User and Theory Guides on Wall Roughness, for example: 4.18.5. Wall Roughness Effects in Turbulent Wall-Bounded Flows
Wall roughness is a method to model equivalent sand-grain roughness, which in real life is a property of the wall surface finish.
- affinity not set
4107
1487
1318
1156
