July 10, 2023 at 12:48 pmeugenio benedettiSubscriber
Hi forum
I'm Eugenio. I'm doing an high number of steady state thermal simulation with radiation. I saw on the solution information that ansys write the view factor calculated into a file.
 WRITING VIEW FACTORS TO FILE
file.vf  Â
I need to change material properties or boundary condition, not the geometry.
there's a possibility to re-use that view factor? It willl be decrease a lot the time of each simulation.thank you all
July 12, 2023 at 10:36 amAshish KhemkaForum Moderator
Hi Eugenio,
Try using the VFOPT READ command.
Ashish Khemka
- The topic ‘view factor into a radiation simulation’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
565
366
