January 14, 2022 at 10:02 am
vishal295
SubscriberHello,
January 14, 2022 at 10:08 pmpeteroznewman
SubscriberYou have enough data to draw a PSD diagram, which is a rectangle.
It starts at 2 Hz with a vertical line, has a horizontal line to 100 Hz then a vertical line. The area under the curve is 0.51g rms.
Use these numbers to calculate the magnitude of the flat line at the top of the PSD. Hint: the units are in g^2/Hz.
January 15, 2022 at 9:07 pmvishal295
SubscriberThank you .
Aah yes yes. I have enough data for psd diagram, and yes I will keep in mind about units.
Thank you and Regards Vishal
Viewing 2 reply threads- The topic ‘Vibration analysis with grms value’ is closed to new replies.
6014
