April 13, 2022 at 6:54 pm
vivek.kamble
SubscriberHello team,
I want to design a Differential Via in HFSS 3D layout, what are the best practices to design and optimize differential via.
Any Video or material will be a great help.
I want to design a four-layer board. Differential microstrip pair at the Top and Bottom layers and their Return-path at layers 2 and 3. Via transition from top to bottom layer.
Thanks,
Vivek
April 19, 2022 at 9:47 amAncS
There is an inbuilt example file of Differential Via in AEDT. You may access it through this path: Open examples > HfFSS 3D layout > Signal Integrity > Diff _Via.aedt
Hope you may find it helpful.
Regards
Anchal
Viewing 1 reply thread- The topic ‘Via Wizard in HFSS 3D layout’ is closed to new replies.
6515
