Electronics
Electronics
Via creation in PCB
    • prajput
      I have a 4 layer PCB, do I need to create a single via or a via array for isolation?
    • Charlotte Blair
      That's all depends on the operating frequency. At low frequency, a single ground via may be sufficient to keep ground as ground but as you go higher in the frequency you may need to create a via fence to keep the signal isolated from other parasitics.
    • prajput
      Thank you for the response.
      How much space should I put between the vias then?
    • Charlotte Blair
      Hi - The rule of thumb is lambda/20 but it depends on your application.
    • prajput
      If I have to consider the fourth harmonic should I decrease the spacing?
    • rtk
      In addition to the above responses, depending on which harmonic you are concerned about will dictate the spacing. From the RF/microwave perspective, more ground vias are better.
Viewing 5 reply threads
  • The topic ‘Via creation in PCB’ is closed to new replies.
