July 7, 2019 at 1:36 am
Weiqiang Liu
SubscriberHi all,
I posted some threads before for a soot cake combustion project. Now I get some results. The maximum temperature during combustion is very close to literature and soot is consumed in similar duration with literature. At first, I believed that I just got perfect results. Then I found the shape of high temperature region was different with literature though the magnitude was very close. I put literature and my result for temperature contour below:
The maximum temperature is very similar which are 853k and 858k respectively. It's just the shape of the high temperature region is different. Then I found that the inconsistency of temperature distribution is because I have very unreasonable velocity field.
I checked my Y-velocity contour and found my model could not capture the effect of end wall. There should be a very large negative Y-velocity at end of the channel wall and gas was forced to flow through porous media to the outlet channel.
I reloaded my UDFs and UDS and then calculated a pure flow instead. Perfect velocity contour was obtained as follows:
As long as UDFs and UDS are involved, velocity contour becomes very unreasonable. More strange thing is though my model can not capture effect of end wall, it can capture the effect of a porous step in front part of the inlet channel. I put the Y-velocity contour near this step below:
At first, I suspected it was due to continuity equation was not converged. Then I checked the pure mass flow between inlet and outlet. The net mass flow showed that continuity was satisfied.
Can anybody give me some suggestions?
BestÂ
Weiqiang
July 8, 2019 at 4:45 am
Amine Ben Hadj Ali
Ansys EmployeeSo without UDF looks good? Even with porous zone right? Gravity us on? Do the UDFs affect the density or viscosity somehow? -
July 8, 2019 at 1:13 pm
Weiqiang Liu
SubscriberHi, Amine,
Yes, without UDF, velocity contour looks perfect with porous zone. Gravity is off. I have a temperature dependent viscosity UDF in source code.Â
Best.
Weiqiang
July 8, 2019 at 1:42 pm
Amine Ben Hadj Ali
Ansys EmployeeSo the transport is influenced.. Can you check the values of the viscosity if they make a sense.?
July 8, 2019 at 1:49 pm
Weiqiang Liu
SubscriberYes, I checked the value of viscosity. I used temperature- dependent equation which is from DIPPR database. Viscosity under 523K is 2.6715e-5 pa.sÂ
I think the viscosity value makes sense.
BestÂ
Weiqiang
July 9, 2019 at 10:34 am
Forum ModeratorPlease can you replot with the node values off? Also can you plot the viscosity in Fluent to check there's not an error with the temperature dependency.Â
July 10, 2019 at 9:09 pm
Weiqiang Liu
SubscriberHi,Â
I found it's problem of permeability. If I give default value of permeability in fluent, continuity equation converges very well and similar velocity contour with literature can be obtained. However, with this very high default permeability, pressure drop across the porous media is totally unreasonable. If I just set normal soot cake permeability, pressure drop is normal and velocity contour becomes unreasonable again.
Therefore I guess, the literature is wrong
Best
Weiqiang
July 11, 2019 at 7:10 am
Amine Ben Hadj Ali
Ansys EmployeeThanks for checking that. Be careful when setting that in Fluent: Fluent expects you are setting the inverse of permeability (1/alpha) not not alpha and not mu/alpha.
July 11, 2019 at 8:11 pm
Weiqiang Liu
SubscriberHi Amine,
Yes, I give 1/alpha in fluent. Thanks very much for your help.
BestÂ
Weiqiang
- The topic ‘velocity contour is very unreasonable while other variable contour is reasonable?’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- convergence issue for transonic flow
- Point exception in erosion calculation
- Script Error Ansys
- Errors with multi-connected bodies using AQWA
- Quantitative results
2743
959
824
599
591
