September 8, 2020 at 9:28 pm
sam
SubscriberHi,
I am using multicomponent particles in the DDPM model. I came across these formulae in the manual, and was wondering which formula (16.160 or 16.161) gets used for vaporization when I select multicomponent particles in 'Injection'?
Is diffusion-controlled the default and do we have to introduce the convection term through an UDS? Or am I understanding it incorrectly?
September 9, 2020 at 2:33 pmRob
Forum ModeratorYou won't need a UDS, read the section below (which tells you what the terms are) and also follow the link to see how B m,i is defined. nSeptember 11, 2020 at 8:23 pmsam
SubscriberDear Rob,nnThank you for your comment, but I do not see anything in the section below where it is mentioned how to activate 16.160 or 16.16. Is there a way to choose which of the two formulae can be used by Fluent?n(Link removed - Rob)nFor B m,i , there are two references that are mentioned, but I do not know where in Fluent is is calculated. nThank you!nSeptember 14, 2020 at 1:35 pmRob
Forum ModeratorIt's activated once multicomponent is set in the DPM Laws from the materials panel. nn
As an aside, Ansys documentation can be accessed directly from Help which is also the latest version.n
Viewing 3 reply threads- The topic ‘Vaporization of multi-component particles’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- convergence issue for transonic flow
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
- Script Error Ansys
Top Contributors-
2537
933
787
599
591
