May 10, 2024 at 9:04 pm
smostafayi
SubscriberI am defining several UDMs in one define at the end UDF, and I am trying to use defined UDMs on another profile UDF. My model is two-phase, mixture model. The profile UDF can not recognize the UDM and consider it as zero. How can I use defined UDM in other codes??
May 14, 2024 at 9:52 am
Rajat Chaudhari
Ansys EmployeeHi Sepehr,
Execute at end will get excute at the end of iteration in steady state and at the end of the time step for transient simulation. While DEFINE_PROFLE will get executed at the start of the iteration.
So please check if values are getting stored in UDM or not.
- The topic ‘Using UDM in UDF’ is closed to new replies.
1306
