May 5, 2022 at 12:24 pmnick5990Subscriber
May 5, 2022 at 2:08 pmJanos PlocherAnsys EmployeeHello nick5990
Thank you for your question and pointing this out. We don see this in the latest version of EduPack (2022R1), as you can see in the image attached. As shown, the value for the recycle fraction ranges between 17.3-19.1% for PET at Level 2. Thus, I would kindly invite to to upgrade to the most recent release.
Just for your understanding: Level 3 databases are updated regularly to match industry changes, while Level 1/2 databases are only updated yearly to allow courses to teach with the same data over a whole academic year - so there can sometimes be discrepancies between data in L2 and L3 as a result.
I hope this helps.
Best János
May 5, 2022 at 4:15 pmnick5990SubscriberHi Janos, I wasn't pointing out a discrepancy (the differences just appear to be due to detail in L2 and L3 databases in my opinion.
It is not possible for me to update CES 2020 to a more recent version as its not been made available for the module I'm studying. Hence please refer to CES Edupak 2020 for this thread.
Please see my previous post re amorphous/ crystalline question which may have been overlooked
May 5, 2022 at 7:23 pmJanos PlocherAnsys EmployeeHi nick5990,
If you would like to include semi-crystalline PET, than you must include the optical properties 'translucent' in your limit stage. This means the material transmits little diffuse light (see science note for more details) and may - depending on the application - also be considered for 'optical' (partially light-resistant) purposes. There are of course specific manufacturing steps that can be taken to make semi-crystalline PET more transparent, but they are not considered here.
You have of course also the option to limit your results by pre-selecting the material family you are looking for, i.e. thermoplastic amorphous or semi-crystalline, but only the former PET variant is considered 'optical quality'.
I hope this answers the question. If not may I kindly ask you to elaborate. Thanks!
May 5, 2022 at 7:54 pmnick5990SubscriberHi j_p, thanks for info re "translucent" - I didn't think to check the definition, and that's valuable what you posted. I'm only interested in "transparent" and "optical".
Re amorphous plastics such as amorphous PET and amorphous PMMA - are these considered solid?
Viewing 4 reply threads
- The topic ‘Using CES edupak to find optical plastics & question re amorphous / semi-crystalline / crystalline’ is closed to new replies.
Ansys Innovation Space
- Chemkin requires HPC
- Calculate heating of an assembly for a given ambient temperature?
- Press hardening characterization
- ACP PRE problem
- CHEMKIN: Chemical reaction kinetics parameter needed
- Documentation of the kinetics of the reaction of methylamine with NO
- Temperature-dependent viscosity model used in FLUENT flow analysis
- Explicit Dynamics Material properties
- orthotropic material proprierties give me “missing” data, what could it be?
- Get ultimate strength value from simulation
591
569
524
366
