Ansys Products
Ansys Products
Unable to proceed after meshing due to this error
    • ZaimAziz93
      anyone knows how to handle this error? In need of your help
    • Raef.Kobeissi
      Hello This is not an installation issue. When you created your mesh you ha e exceeded 512,000 elements which is not allowed in an Free Academic License. The maximum you can have is 512,000 cells anything above that will not go to the next stage. You need to reduce the number of cells in your mesh.
      Cheers
    • ZaimAziz93
      Noted and thank you sir. Very much appriciated
    • murthy2421
      Hi Raef, I faced similar problem, using the educational license I created a mesh  with more than 512000 cell and imported it to a research license Ansys. But its still giving me same problem, what can I do now ?
      Read this discussion and see if it applies to your case.
Viewing 4 reply threads
  • The topic ‘Unable to proceed after meshing due to this error’ is closed to new replies.
