TAGGED: ansys-workbench, error, maxwell, steady-state-thermal
November 20, 2020 at 6:54 pmarshiahSubscriberHello, nWhen I tried to run Workbench files (Maxwell and Steady state coupled) made in 2015 version on ANSYS 2019 version, I get these errors. But when I open the workbench file. The geometry in the Maxwell file is missing, and I am not able to change any parameters Thermal steady state file (it has gone into read-only mode). nSystem.IO.IOException: Access to the path 'C:\Users\usedid\Desktop\foldername\USB Drive\1.Thermal 2D archive\Thermal_2D_files\dpall\global\Ansoft\project_R3_mica insulation.aedtresults\Benchmark_Insl_Rchange_mica.results' is denied.n  at Ansys.Ansoft.CoreAddin.Migration.MigrationHandlerMoveHFSSDesignerQ3dIntoAnsysEDT.PostProjectLoadDelegate(IFullContext context)n  at Ansys.Ansoft.CoreAddin.Migration.PostProjectLoadMigrationHelper.DoPostProjectLoadMigration(IFullContext context) at Ansys.Ansoft.CoreAddin.Events.ProjectReplaceDoneEventObserver.Receive(IEvent eventInfo)  at Ansys.Core.Events.EventInvoker.Invoke()nn
November 24, 2020 at 4:53 pmANSYS_MMadoreAnsys EmployeeAre you able to work with 2019 version of files?.ThanksnMattn
November 24, 2020 at 5:20 pmarshiahSubscriberI do not have a 2019 version of these files. Is there any way I can change their version to 2019. I have maxwell and steady state files in the 2015 version of workbench file. n
November 24, 2020 at 5:27 pmANSYS_MMadoreAnsys EmployeeI'm asking if you are able to create new files, just to ensure that your 2019 is working, separate from the specific 2015 projects.n
November 24, 2020 at 5:31 pmarshiahSubscriberyes, I am able to run my other 2019 files, so my 2019 is working. Thanks.n
November 24, 2020 at 5:35 pmarshiahSubscriberOkay, Thank you n
November 25, 2020 at 9:43 ammbeliaevAnsys Employeedo you have EM files outside of WB?nI think this is the simplest way to decouple WB and Maxwell issuesn
Viewing 6 reply threads
- The topic ‘Unable to open ANSYS 2015 files on ANSYS 2020’ is closed to new replies.
Ansys Innovation Space
- Speed up simulation in HFSS
- Workbench license error
- ansys fluent error when opening it “unexpected license problem”
- Unexpected error on Workbench: Root element not found.
- not able to get result
- Unable to recover corrupted project in Workbench
- Unattended (silent) installation of 2024R2 & -productfile switch
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
513
488
225
209
