September 2, 2024 at 5:49 pm
ay8tb
SubscriberI have an academic license from the university and the license has expired. I did a clean uninstall and reinstall and am receiving the following error from ANSYS Client Licensing Center:
lmutil - Copyright (c) 1989-2022 Flexera. All Rights Reserved. Flexible License Manager status on Mon 9/2/2024 13:45 [Detecting lmgrd processes...] Error getting status: Cannot connect to license server system. (-15,10032) Error: Command failed: C:\Program Files\ANSYS Inc\v222\licensingclient\winx64\lmutil.exe lmstat -c XXX@XXX.license.XXX.eduI've run this as administrator on the university VPN and keep receiving the same error. I've double-checked the port and licensing number and it's correct. What can I do?
September 4, 2024 at 11:54 am
Rajeshwari Jadhav
Forum ModeratorHi Ayatollah,
send screenshot of ping and telnet through command prompt.
ping yourservername
telnet yourservername portno.
January 8, 2025 at 1:08 pm
manuel.dattoli
Subscriberanche a me da questo problema
November 1, 2025 at 10:19 am
darshanhr402
Subscriber_amber
lmutil - Copyright (c) 1989-2024 Flexera. All Rights Reserved. Flexible License Manager status on Sat 11/1/2025 15:45 [Detecting lmgrd processes...] Error getting status: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)") Error: Command failed: C:\Program Files\AGI\STK_ODTK 13\licensingclient\winx64\lmutil.exe lmstat -c 45022@1 -
November 3, 2025 at 2:43 pm
Rajeshwari Jadhav
Forum ModeratorHi Darshan,
Please follow the below method.
- Add entries in hosts file (take help from your IT team to add the server IP entry and save the hosts file which needs admin access)
- Open the HOSTS file on client machine on notepad (open empty notepad as an admin) and add the license server name and IP of the license server in that hosts file.
- Path: “ C:\Windows\system32\drivers\etc\hosts file “ as per the following format in your client machine :
- Path: For linux you can goto etc/hosts file (root access) and at the end add entries
IP Address Servername FQDN
xxx.xxx.xxx.xxx abcd abcd.win.com
where,
xxx represents the IP address of server
abcd represents the name of your server
abcd.win.com represents the name of your fully qualified domain name
March 1, 2026 at 6:41 pm
agirish35
Subscriberlmutil - Copyright (c) 1989-2024 Flexera. All Rights Reserved. Flexible License Manager status on Sun 3/1/2026 13:29 [Detecting lmgrd processes...] Error getting status: Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused"). I am getting this error after entering the hostname and port into license settings. What is wrong?
6445
