September 15, 2021 at 4:11 am
AaronHuang
SubscriberHi,
The pop-up window "Edit Material Properties" for Solid alloy was scrambled up, as shown below. The other pop-up windows are normal, I've tried restarting the application and computer, but it still scrambled up! How can I solve this problem?
Many thanks!
September 15, 2021 at 6:41 pmGeorge Karnos
Ansys EmployeeMake sure no Ansys programs are running
Under %APPDATA%\Ansys you should see a directory associated with the version you are running:
EX: for 2021 R2 you will see: %APPDATA%\Ansys\v212
Rename v212 to v212.old
Now try again.
September 15, 2021 at 10:49 pmLito
Ansys EmployeeAlso remove the 'Lumerical Device.ini' file from the %APPDATA%\Lumerical\ folder.
September 16, 2021 at 1:30 amSeptember 16, 2021 at 5:31 pmLito
Ansys EmployeeThis could be an issue with your graphics/display. Try the following:
See this post for suggestions Use a display resolution around 1920x1080, or
Disable "3D display mode"
Viewing 4 reply threads- The topic ‘UI error – Lumerical Multiphysics’ is closed to new replies.
