Electronics
Electronics
Two ‘MotionSetup’ in Maxwell 2D/3D
    • sanket.joshi
      I want to assign two motion setups in model to simulate two rotating parts with a stationary part in them (images attached). When I create two motion setups, validation check is all green ticks, but it throws error as "Multiple solution domain detected". Is it possible to do so at all or does it need any additional setup to run...
    • sanket.joshi
      Well it works with two non intersecting bands, the error i had was because of setting a boundary condition to one of the edge of band object's geometry
    • GLUO
      Maxwell support this setup. You will need additional inner band inside both motion band.
      GL
    • sanket.joshi
      so total three motion setups for two moving bands?
      and the in between one - that too a "rotational"?
      • GLUO
        No, in your ring shaped motion band, you need a smaller ring that inside the ring to include the moving objects.
      • GLUO
        The inner band is just a vacuum object. You do not need to assign anyting on it.
    • sanket.joshi
      Understood, thanks for clarification...
      it works as of now with my existing setup...
Viewing 4 reply threads
