October 26, 2021 at 4:39 pmKadhirSubscriber
I have a design that has bolt pretension. I want to check at what Bolt pretension will the design fail. It is a Non linear analysis so I am using Multilinear curve to carry out analysis. The Material property is 348 MPa Yield strength and 580 MPa UTS. The True strength value for Ultimate tensile changes to 950 MPa using Pressure vessel code. I analyzed for various Bolt pretension and at 80 kN, the Von misses stress generated was 702 MPa. Since the values generated by Ansys are Always True stress- strain values, What should I compare this value to? Engineering UTS (580 MPa) or else the True value of UTS (950 MPa)?
October 27, 2021 at 10:24 pmDavid MercierAnsys EmployeeHi, I let you check this Q/A which might help you: /forum/discussion/comment/94857#Comment_94857
Then if you need more material data or stress-strain curves to use in your numerical analysis without doing a multilinear curve modeling, you can have a look into Granta EduPack or Granta Selector databases: https://www.ansys.com/products/materials/granta-selector.
Especially for the bolt, we have specific database for that.
Viewing 1 reply thread- The topic ‘True stress versus Engineering stress’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Chemkin requires HPC
- Calculate heating of an assembly for a given ambient temperature?
- Press hardening characterization
- ACP PRE problem
- Explicit Dynamics Material properties
- Documentation of the kinetics of the reaction of methylamine with NO
- Temperature-dependent viscosity model used in FLUENT flow analysis
- orthotropic material proprierties give me “missing” data, what could it be?
- Get ultimate strength value from simulation
Top Contributors-
1406
599
591
555
366
