July 24, 2025 at 2:29 pm
raano1
SubscriberDear Ansys Support Team,
I reviewed the example “Topology optimization of an O-band/C-band wavelength de-multiplexer with 100nm feature size constraint” on your Knowledge Base (https://optics.ansys.com/hc/en-us/articles/4403241716371), but could not find the following:
Full 3D Python script (topology.py)
Required .lsf simulation files
GDSII export instructions or script
Steps to extract and plot the transmission spectrum
Could you please provide these or direct me to where I can access them? -
July 24, 2025 at 4:51 pm
July 24, 2025 at 5:26 pm
raano1
SubscriberThank you for the update. I’ll follow up in the Photonics forum. Please let me know if the requested files or instructions will be shared there.
July 24, 2025 at 6:43 pm
Kirill
Forum ModeratorDear Subscriber,
Thank you for reporting this. We’ll look into why the mentioned content is missing.
In the meantime, I suggest reviewing these two related examples:
- Topology Optimization of a 4-channel wavelength demultiplexer 2D-TE
- Inverse Design of a Splitter Using Topology OptimizationBest regards,
Kirill -
July 24, 2025 at 6:51 pm
raano1
SubscriberDear Kirill,
Thank you for the quick response and for sharing the related examples. I’ll review them in the meantime.I would appreciate it if you could provide the missing content from the original example as early as possible, as I specifically need that example code for my work.
Looking forward to your update.
July 28, 2025 at 2:21 pm
raano1
Thanks for your response.
I’m working on the “Topology Optimization of a 4-channel wavelength demultiplexer 2D-TE” and would like to adapt it for a 100 nm feature size. How can I implement this?
Also, is there any update on the O-band/C-band demultiplexer example with a 100 nm feature constraint?
July 28, 2025 at 4:32 pm
anna.wirth-singh
Ansys EmployeeHello,
I can answer that question about how to implement the minimum feature size constraint. Please see this reference, towards the bottom of the article, for details on the topology settings: Optimizable Geometry - Python API – Ansys Optics
The parameter you will need to adjust is 'filter_R'. It is set to 200nm by default.
Best,
Anna
July 29, 2025 at 3:27 pm
raano1
SubscriberDear Anna,
Thank you for your previous guidance on minimum feature size in topology optimization.
Following your advice, I’ve been exploring the filter_R parameter to reliably achieve a 100 nm minimum feature size. I understand there's a trade-off between stability and precision, and I've seen three common approaches:
filter_R = 50 nm: targets 100 nm (since min feature ≈ 2×filter_R)
filter_R = 100 nm: matches the feature size and seems commonly used
filter_R = 200 nm: a safe default yielding smoother, larger features
I’m also unclear on best practice for setting min_feature_size in the DFM stage. The documentation states it must satisfy:
filter_R < min_feature_size < 2×filter_R
Could you please advise which filter size—50 nm, 100 nm, or 200 nm—is appropriate for achieving a 100 nm feature size? -
July 30, 2025 at 3:42 pm
raano1
I hope this message finds you well.
After completing a 3D TE topology optimization run using Lumerical and adjoint methods, I noticed that the output directory (e.g.,
3D_TE_topology_x3000_y_2000_f0100_0
) contains multiple subfolders such asopts_0
,opts_1
,convergence_report
,.npz
, and.vtr
files. However, I do not see any.fsp
(Lumerical project) file generated.Could you please clarify:
How can I generate a
.fsp
file from the optimization results, if it is not automatically produced?
How to export the final device contour to GDS format?
How to visualize the transmission spectrum from the available output files?
Any guidance or documentation link would be greatly appreciated.
Also,could you please advise which filter size—50 nm, 100 nm, or 200 nm—is appropriate for achieving a 100 nm feature size? -
July 30, 2025 at 5:07 pm
anna.wirth-singh
Ansys EmployeeHi, thanks for the additional questions, I’ll answer as many as I can.
1.If you do not see a final .fsp file dropped into the main folder, please look into the subfolder with the highest number (opts_1) and find the ‘forward_n.fsp’ also with the highest number. Each time you initiate the optimization process, it will create a new folder and then inside that folder there will be forward and adjoint simulation files corresponding to that part of the optimization. The most recently produced forward.fsp file will contain the optimized result.
2. Please see this page for reference on the GDS export process: GDS pattern extraction for inverse designed devices using contours method – Ansys Optics
3. To visualize the transmission spectrum, you should add a Mode expansion monitor – Simulation object – Ansys Optics over the output waveguide. You should look for the T_forward or T_backward result (depending on which direction your monitor is facing), as described here: Using and understanding Mode Expansion Monitors – Ansys Optics -
July 30, 2025 at 5:28 pm
raano1
Following your advice, I’ve been exploring the filter_R parameter to reliably achieve a 100 nm minimum feature size. I understand there’s a trade-off between stability and precision, and I’ve seen three common approaches:
I’m also unclear on best practice for setting min_feature_size in the DFM stage. The documentation(Optimizable Geometry – Python API – Ansys Optics) states it must satisfy:
Also,In Lumerical inverse design using Python, if I set up the simulation to observe the transmission spectrum, is it possible to automatically view it when the code finishes running? For example, after the script generates the .fsp file and other outputs, can I add some code to display the transmission spectrum at the end? -
July 31, 2025 at 4:22 pm
anna.wirth-singh
Ansys EmployeeHi,
I looked into your question about the settings a bit more deeply. Both filter_R and min_feature_size are meant to implement a minimum feature size in designs to ensure manufacturability, but they are implemented at different stages of the optimization process. Even with spatial filtering (filter_R) , the process may create some features that break the rules. To add additional constraints, min_feature_size is additionally used to penalize designs that do not follow the minimum feature size rules. Topology optimization is unique to the setup that you have, so there is not a one-size-fits-all approach, but I think it would be safe to set min_feature_size = 100nm and then the filter_R a bit smaller (perhaps 75nm) if you are using the DFM phase.
And yes, it is possible to use the Python API (Python API overview – Ansys Optics) to display a plot in Matplotlib. This page has an example code snippet that may be useful: Script Commands as Methods - Python API – Ansys Optics
Best,
Anna
August 4, 2025 at 6:24 pm
raano1
SubscriberDear Ansys Support,
After the topology optimization, I opened the generated
forward_0.fsp
file and ran the attached script in the FDTD Script Editor. I’ve also attached the resulting transmission plot.I noticed that the transmission between 600 nm and 800 nm is visible in the spectrum, but the transmission below 600 nm is missing.
image, where it seems the light is transmitting through Channel 2, not Channel 1. Could you please explain why this is happening?Could you please confirm if this is the correct workflow and if the script is valid?
Thank you for your support.
import lumapi
import matplotlib.pyplot as plt# Update fsp_path to your new file location
fsp_path = r”D:\Lumerical_projects\wdm\diamond_2_3D_TE_topology_x3000_y2000_f0075_0\opts_1\forward_0.fsp”fdtd = lumapi.FDTD()
fdtd.load(fsp_path)transmission_1 = fdtd.getresult(‘fom_1’, ‘T’)
transmission_2 = fdtd.getresult(‘fom_2’, ‘T’)wavelengths_1 = transmission_1[‘lambda’] * 1e9 # convert to nm
data_1 = transmission_1[‘T’]wavelengths_2 = transmission_2[‘lambda’] * 1e9
data_2 = transmission_2[‘T’]plt.figure(figsize=(8,5))
plt.plot(wavelengths_1, data_1, label=’Channel 1 (520-540 nm)’)
plt.plot(wavelengths_2, data_2, label=’Channel 2 (600-800 nm)’)
plt.xlabel(‘Wavelength (nm)’)
plt.ylabel(‘Transmission’)
plt.title(‘Transmission Spectra for Both Channels’)
plt.legend()
plt.grid(True)# Force x-axis to show 500 nm to 800 nm
plt.xlim(500, 800)plt.show()
August 5, 2025 at 2:11 am
Kirill
This issue is difficult to resolve without access to the details of your simulation. Unfortunately, the format of this forum isn’t well suited for handling such cases.
However, you may be eligible for support through the Ansys Customer Support Space (ACSS), where we can assist you more effectively.
For details, please refer to How to register on Ansys Customer Support Space. Please try submitting your request there.Best regards,
Kirill -
August 5, 2025 at 5:00 pm
raano1
Dear Ansys Support,
I’m working on a design similar to the O-band/C-band wavelength demultiplexer described in the following article:However, my transmission goal is to achieve high efficiency over the 520–540 nm and 600–800 nm ranges, with each output channel reaching over 95% transmission in its respective band, as shown in the attached transmission plot.I’ve already created both the base simulation setup and the Python optimization script. Could you please review them along with my transmission analysis code to confirm if everything is correctly implemented?Thank you for your support.base simulation code :switchtolayout;selectall;delete;## SIMULATION PARAMETERS# Waveguide and Geometry Parametersnum_wg = 2;wg_width = 0.5e-6;wg_height = 0.22e-6;out_wg_dist = 1e-6;total_wg_h_span = num_wg*wg_width + (num_wg-1)*out_wg_dist;# Optimization and Simulation Region Sizeopt_size_x = 3e-6;opt_size_y = 2e-6;opt_size_z = wg_height;size_x = opt_size_x + 1e-6;size_y = opt_size_y + 1e-6;size_z = 1.2e-6;# Material and Mesh Parameterswg_index = 2.417;bg_index = 1.46;fine_mesh_size = 20e-9;## GEOMETRY SETUP# Input Waveguideaddrect;set('name','input wg');set('x min',-size_x);set('x max',-opt_size_x/2 + 5e-7);set('y',0);set('y span',wg_width);set('z', 0);set('z span', wg_height);set('index',wg_index);# Output Waveguidesfor( i=1:num_wg ) {addrect;set('name','output wg '+num2str(i));set('x min',opt_size_x/2 - 5e-7);set('x max',size_x);set('y',-total_wg_h_span/2 + (wg_width/2) + (i-1)*(out_wg_dist+wg_width));set('y span',wg_width);set('z', 0);set('z span', wg_height);set('index',wg_index);}## SOURCE SETUPaddmode;set('direction','Forward');set('injection axis','x-axis');set('x',-size_x/2+0.2e-6);set('y',0);set('y span',3*wg_width);set('z',0);set('z span',size_z - 0.2e-6);set('center wavelength',500e-9);set('wavelength span',0);set('mode selection','fundamental TE mode');## FDTD SIMULATION REGION (FDTD)addfdtd;set('dimension','3D');set('index',bg_index);set('mesh accuracy',3);set('x min',-size_x/2);set('x max',size_x/2);set('y min',-size_y/2);set('y max',size_y/2);set('z min',-size_z/2);set('z max',size_z/2);set('z min bc','PML');set('z max bc','PML');set('auto shutoff min',1e-6);set('simulation time',5000e-15);## MESH REFINEMENT FOR 100nm FEATURESaddmesh;set('name','opt_mesh');set('x',0);set('x span',opt_size_x);set('y min',-opt_size_y/2);set('y max',opt_size_y/2);set('z', 0);set('z span', opt_size_z);set('override x mesh',true);set('dx',fine_mesh_size);set('override y mesh',true);set('dy',fine_mesh_size);set('override z mesh',true);set('dz',fine_mesh_size);## MONITORS# Optimization Fields Monitoradddftmonitor;set('name','opt_fields');set('monitor type','3D');set('x',0);set('x span',opt_size_x);set('y min',-opt_size_y/2);set('y max',opt_size_y/2);set('z', 0);set('z span', opt_size_z);# FOM (Figure of Merit) Monitorsfor( i=1:num_wg ) {y_center = -total_wg_h_span/2 + (wg_width/2) + (i-1)*(out_wg_dist+wg_width);adddftmonitor;set('name','fom_'+num2str(i));set('monitor type','2D X-normal');set('x', size_x/2-0.2e-6);set('y', y_center);set('y span', 3*wg_width);set('z min', -size_z/2);set('z max', size_z/2);}# Global Index Monitor (for visualization)addindex;set('name','global_index');set('monitor type','3D');set('x min',-size_x/2);set('x max',size_x/2);set('y min',-size_y/2);set('y max',size_y/2);set('z min',-size_z/2);set('z max',size_z/2);## INITIAL GUESS# addstructuregroup;# set("name","initial_guess");# for( i=1:num_wg ) {# y_out = -total_wg_h_span/2 + (wg_width/2) + (i-1)*(out_wg_dist+wg_width);# addwaveguide;# set("name","bend"+num2str(i));# set("base width", wg_width);# set("base height", wg_height);# set("base angle",90);# poles = [-opt_size_x/2, 0;# 0, 0;# 0, y_out;# opt_size_x/2, y_out];# set("poles",poles);# set("index",wg_index);# addtogroup("initial_guess");# }python code for optimization:######## IMPORTS ######### General purpose importsimport osimport sysimport numpy as np# Optimization specific importsfrom lumopt import CONFIGfrom lumopt.geometries.topology import TopologyOptimization2D,TopologyOptimization3DLayered from lumopt.utilities.load_lumerical_scripts import load_from_lsf from lumopt.figures_of_merit.modematch import ModeMatch from lumopt.optimization import Optimizationfrom lumopt.optimizers.generic_optimizers import ScipyOptimizers from lumopt.utilities.wavelengths import Wavelengths######## DEFINE BASE SIMULATION ########def runSim(params, eps_bg, eps_wg, x_pos, y_pos,z_pos, size_x, size_y,size_z, filter_R, min_feature_size, working_dir, beta):######## DEFINE GEOMETRY ########geometry =TopologyOptimization3DLayered( params=params, eps_min=eps_bg, eps_max=eps_wg, x=x_pos, y=y_pos,z=z_pos, filter_R=filter_R, min_feature_size=min_feature_ size, beta=beta) ######## DEFINE FIGURE OF MERIT FOR EACH OUTPUT WAVEGUIDE ########fom1 = ModeMatch(monitor_name = 'fom_1', mode_number = 'Fundamental TE mode', direction = 'Forward', norm_p = 2, target_fom=1)fom2 = ModeMatch(monitor_name = 'fom_2', mode_number = 'Fundamental TE mode', direction = 'Forward', norm_p = 2, target_fom=1)######## DEFINE OPTIMIZATION ALGORITHM ########optimizer = ScipyOptimizers(max_iter=800, method='L-BFGS-B', pgtol=1e-6, ftol=1e-5, scale_initial_gradient_to=0.25) ######## DEFINE SETUP SCRIPT AND INDIVIDUAL OPTIMIZERS ########script = load_from_lsf('D:/Lumerical_projects/wdm/base_diamond_2. lsf') script = script.replace('opt_size_x=3e-6','opt_size_x={:1.6g}'. format(size_x)) script = script.replace('opt_size_y=2e-6','opt_size_y={:1.6g}'. format(size_y)) wavelengths1 = Wavelengths(start = 520e-9, stop = 540e-9, points = 11)opt1 = Optimization(base_script=script, wavelengths = wavelengths1, fom=fom1, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=True, plot_history=False, store_all_simulations=False, save_global_index=True) wavelengths2 = Wavelengths(start = 600e-9, stop = 800e-9, points = 11)opt2 = Optimization(base_script=script, wavelengths = wavelengths2, fom=fom2, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=True, plot_history=False, store_all_simulations=False, save_global_index=False) ######## PUT EVERYTHING TOGETHER AND RUN ########opt = opt1+opt2opt.run(working_dir = working_dir)if __name__ == '__main__':size_x = 3000size_y = 2000size_z = 220filter_R = 75e-9min_feature_size=100e-9x_points=int(size_x/20)+1y_points=int(size_y/20)+1z_points=int(size_z/20)+1eps_wg = 2.417**2eps_bg = 1.46**2x_pos = np.linspace(-size_x/2*1e-9,size_x/2*1e-9,x_points) y_pos = np.linspace(-size_y/2*1e-9,size_y/2*1e-9,y_points) z_pos = np.linspace(-size_z/2*1e-9,size_z/2*1e-9,z_points) ## We need to pick an initial condition. Many different options:params = 0.5*np.ones((x_points,y_points)) #< Start with the domain filled with (eps_wg+eps_bg)/2 #params = np.ones((x_points,y_points)) #< Start with the domain filled with eps_wg#params = np.zeros((x_points,y_points)) #< Start with the domain filled with eps_bg#params = None #< Use the structure defined in the project file as initial conditionworking_dir = 'diamond_2_3D_TE_topology_x{:04d}_y{:04d}_f{:04d}'.format( size_x,size_y,int(filter_R* 1e9)) runSim(params, eps_bg, eps_wg, x_pos, y_pos,z_pos, size_x*1e-9, size_y*1e-9,size_z*1e-9,filter_R, min_feature_size,working_dir= working_dir, beta=1)
After completing the topology optimization, the process generated aforward_0.fsp
), which I’ve attached.I then opened the
forward_0.fsp
file and ran the attached FDTD script. I’ve also included the resulting transmission plot.I noticed that transmission between 600 nm and 800 nm is visible in the spectrum, but there is no transmission below 600 nm.
image, it appears that light is mainly transmitting through Channel 2, not Channel 1. Could you please explain why this might be happening?Could you also confirm whether my workflow and script are correct?
code for see the transmission:import lumapiimport matplotlib.pyplot as plt# Update fsp_path to your new file locationfsp_path = r"D:\Lumerical_projects\wdm\diamond_2_3D_TE_topology_ x3000_y2000_f0075_0\opts_1\ forward_0.fsp" fdtd = lumapi.FDTD()fdtd.load(fsp_path)transmission_1 = fdtd.getresult('fom_1', 'T')transmission_2 = fdtd.getresult('fom_2', 'T')wavelengths_1 = transmission_1['lambda'] * 1e9 # convert to nmdata_1 = transmission_1['T']wavelengths_2 = transmission_2['lambda'] * 1e9data_2 = transmission_2['T']plt.figure(figsize=(8,5))plt.plot(wavelengths_1, data_1, label='Channel 1 (520-540 nm)')plt.plot(wavelengths_2, data_2, label='Channel 2 (600-800 nm)')plt.xlabel('Wavelength (nm)')plt.ylabel('Transmission')plt.title('Transmission Spectra for Both Channels')plt.legend()plt.grid(True)# Force x-axis to show 500 nm to 800 nmplt.xlim(500, 800)plt.show() -
August 7, 2025 at 8:05 pm
Taylor Robertson
I don't believe that the optimization has run to completion, but it looks like the Transmission targets are pretty close to the target. I don't believe that DFM is being allowed to complete. Maybe reduce the max_iterations ~200.
Because you have two channels and wavelength targets there are multiple simulations being run. The results you are looking at are for the second target 600-800nm. You can look at "opts_0\forward_0.fsp” to see the other wavelength target.
Alternatively, I would adjust the bandwidth in the final simulation and plot the results for 500-800nm.
fdtd.load(fsp_path)
fdtd.switchtolayout()
fdtd.setglobalsource('wavelength start',500e-9)
fdtd.setglobalsource('wavelength stop',800e-9)
fdtd.setglobalmonitor('frequency points',100)
fdtd.run()
Some other things to consider, you are using a single index value of 2.417 for the whole bandwidth, while there is likely dispersion. The filter_R parameter is the radius of the convolution filter used in the grescale and binarization. This isn't guaranteed to to achieve a minimum feature size, but is intended to close out small features in the topology object - box blur. There is no definitive answer here, you can play around to see how this effects performance and minimum feature size. The DFM step, actually penalizes the FOM when minimum features are present, and then optimizes; however, I don't think you have run the DFM step for this device.Best Regards,
August 18, 2025 at 4:51 pm
raano1
SubscriberPlease see the next reply...
August 20, 2025 at 2:17 pm
raano1
August 21, 2025 at 5:51 pm
raano1
I have two questions.
First:
To see the transmission spectrum result, I am using the Python code, and I can already view the result. Do I also need to add a mode expansion monitor?Second:
I am increasing some parameters, such as the waveguide width and height, for my research purpose. When I run the Python code, I get the following error:numpy._core._exceptions._ArrayMemoryError: Unable to allocate 2.00 GiB for an array with shape (301, 401, 101, 11) and data type complex128
This happens even though my computer has 128 GB of RAM. I’m running Windows (C:), where my C drive has 728 GB of free space, and I’m running the code from the D drive, which has 3.56 TB of free space.
How can I solve this problem? Please guide me properly.
I am attaching both my base simulation code and Python code.
Second -
Base simulationswitchtolayout;
selectall;
delete;
num_wg = 2;
wg_width = 3.0e-6;
wg_height = 2.0e-6;
out_wg_dist = 1e-6;
opt_size_x = 6e-6;
opt_size_y = 8e-6;
size_z = 3.2e-6;
wg_index = 2.417;
bg_index = 1.46;
## GEOMETRY SETUP
# Input Waveguide
addrect;
set(‘name’,’input wg’);
set(‘x min’,-size_x);
set(‘x max’,-opt_size_x/2 + 5e-7);
set(‘y’,0);
set(‘y span’,wg_width);
set(‘z’, 0);
set(‘z span’, wg_height);
set(‘index’,wg_index);
# Output Waveguides
for( i=1:num_wg ) {
addrect;
set(‘name’,’output wg ‘+num2str(i));
set(‘x min’,opt_size_x/2 – 5e-7);
set(‘x max’,size_x);
set(‘y’,-total_wg_h_span/2 + (wg_width/2) + (i-1)*(out_wg_dist+wg_width));
set(‘z’, 0);
## SOURCE SETUP
addmode;
set(‘direction’,’Forward’);
set(‘injection axis’,’x-axis’);
set(‘x’,-size_x/2+0.2e-6);
set(‘y’,0);
set(‘y span’,1.7*wg_width);
set(‘z’,0);
set(‘z span’,size_z – 0.2e-6);
set(‘center wavelength’,500e-9);
set(‘wavelength span’,0);
set(‘mode selection’,’fundamental TE mode’);
addfdtd;
set(‘dimension’,’3D’);
set(‘index’,bg_index);
set(‘mesh accuracy’,3);
set(‘x min’,-size_x/2);
set(‘x max’,size_x/2);
set(‘y min’,-size_y/2);
set(‘y max’,size_y/2);
set(‘z min’,-size_z/2);
set(‘z max’,size_z/2);
set(‘z min bc’,’PML’);
set(‘z max bc’,’PML’);
set(‘auto shutoff min’,1e-6);
set(‘simulation time’,5000e-15);
addmesh;
set(‘name’,’opt_mesh’);
set(‘x’,0);
set(‘x span’,opt_size_x);
set(‘y min’,-opt_size_y/2);
set(‘y max’,opt_size_y/2);
set(‘z’, 0);
set(‘z span’, opt_size_z);
set(‘override x mesh’,true);
set(‘dx’,fine_mesh_size);
set(‘override y mesh’,true);
set(‘dy’,fine_mesh_size);
set(‘override z mesh’,true);
set(‘dz’,fine_mesh_size);
## MONITORS
adddftmonitor;
set(‘name’,’opt_fields’);
set(‘monitor type’,’3D’);
set(‘x’,0);
set(‘z’, 0);
for( i=1:num_wg ) {
adddftmonitor;
set(‘name’,’fom_’+num2str(i));
set(‘monitor type’,’2D X-normal’);
set(‘x’, size_x/2-0.2e-6);
set(‘y’, y_center);
set(‘y span’, 1.7*wg_width);
set(‘z min’, -size_z/2);
set(‘z max’, size_z/2);
addindex;
set(‘name’,’global_index’);
Python code
import os
import sys
import numpy as np
geometry =TopologyOptimization3DLayered(params=params, eps_min=eps_bg, eps_max=eps_wg, x=x_pos, y=y_pos,z=z_pos, filter_R=filter_R, min_feature_size=min_feature_size, beta=beta)
fom1 = ModeMatch(monitor_name = ‘fom_1’, mode_number = ‘Fundamental TE mode’, direction = ‘Forward’, norm_p = 2, target_fom=1)
fom2 = ModeMatch(monitor_name = ‘fom_2’, mode_number = ‘Fundamental TE mode’, direction = ‘Forward’, norm_p = 2, target_fom=1)
optimizer = ScipyOptimizers(max_iter=200, method=’L-BFGS-B’, pgtol=1e-6, ftol=1e-5, scale_initial_gradient_to=0.25)
script = load_from_lsf(‘C:/Lm projects/wdm_1/base_diamond.lsf’)
script = script.replace(‘opt_size_x= 6e-6′,’opt_size_x={:1.6g}’.format(size_x))
script = script.replace(‘opt_size_y= 8e-6′,’opt_size_y={:1.6g}’.format(size_y))
opt = opt1+opt2
if __name__ == ‘__main__’:
size_x = 6000
size_y = 8000
size_z = 2000
filter_R = 75e-9
eps_wg = 2.417**2
eps_bg = 1.46**2
working_dir = ‘diamond_3D_TE_topology_x{:04d}_y{:04d}_f{:04d}’.format(size_x,size_y,int(filter_R*1e9))
runSim(params, eps_bg, eps_wg, x_pos, y_pos,z_pos, size_x*1e-9, size_y*1e-9,size_z*1e-9,filter_R, min_feature_size,working_dir=working_dir, beta=1)
August 21, 2025 at 8:05 pm
Taylor Robertson
The lumopt pakage will add a mode expansion monitor MEM based on the FOM - frequency monitor you define, and the modes(number, direction) and wavelengths specified in other objects ModeMatch and Wavelengths. It is not necessary to define the MEM explicitly, just like the adjoint source is set-up automatically in the backward sims.
I have never seen this issue with numpy memory, but it is a Numpy problem and not something we can support.
It seems like the only workaround I can tell is exploring ways of reducing the data in the opt_fields monitor. You can do this by making it smaller, making the mesh larger or reudcing the number of wavelengths. For example you probably don't need 20nm mesh in the z direction.
I will need to look into this a bit further, but for some reason your array is 128bit complex. We could almost certainly reduce that to 32bit float to help avoid this issue in the future.
3777
1388
1188
1090
1015
