Process Integration and Design Optimization
Topological Optimization of Regenerative Cooling Channels
    • paaulocz
      Hello everyone, I would like to know if Ansys supports topological optimization of regenerative cooling channels with the purpose of reducing temperature.
      In this case, I believe there would be a fluid domain to be optimized, based on the temperature field of the solid domain in contact.
      Ansys has a structural topological optimization module, but I haven't been able to see the proper workflow yet.
      Thanks in advance!
    • Murari Iyengar
      Hi Paulo, Fluent has a gradient based shape optimization model, not a topological optimizer. You can refer to this tutorial to get started. Chapter 29: Using the Adjoint Solver – 2D Laminar Flow Past a Cylinder (ansys.com)
  • The topic ‘Topological Optimization of Regenerative Cooling Channels’ is closed to new replies.
