January 20, 2025 at 11:51 pm
dkmenend
SubscriberHello,
I am running a case with an explicit time step method. I am wondering what it means when i get the message "Timestep reduced in # cells due to excessive pressure/temp change"
How does fluent only reduce the timestep in some of the cells? Does it run multiple iterations on just those cells while the rest of the mesh is calculated once?
Thank you for your explanations.Â
January 23, 2025 at 2:15 pm
Essence
Ansys EmployeeHello,
Please check the mesh and case settings to avoid getting the message.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
823
599
591
366
