April 4, 2023 at 10:35 pm
YH
SubscriberHello,
I'm calculating acoustic pressure inside pipe using LES+Ffowcs Willams and Hawkings (FW-H) model.
During the calcualtion, I noticed that the results extremly depend on the time stpe size. I tried that time step size 5E-5, 1.1E-6 and 5E-7 sec. And the result is the figure below. The time step size is smaller, the peaks shift to right. I calculated this result by the steps;
1) ANSYS fluent calcuates acoustics pressure with LES+FW-H model
2)Power spectral density (psd) is calculated from the acoustic pressure
3)spl = dB(sqrt(psd*df))
Do you have any idea why the peak of the sound pressure level shift to large when the time step size becomes small?
And how much should I decrease the time step size?
Thanks!
April 5, 2023 at 12:25 pm
Federico
Ansys EmployeeHello,
I suggest you look into aliasing errors, which occurs in a FFT due to insufficient sampling of a high frequency signal.
- The topic ‘Time step size for Acoustic Simulation’ is closed to new replies.
2788
965
851
599
591
