There is not enough memory for the Distributed Sparse Matrix Solver to proceed using the out-of-core
    • bharath_reddy1
      Trying to analyze a structural module for large deflections and got the below error.
       *** ERROR ***              CP =   731.672  TIME= 23:34:24
       There is not enough memory for the Distributed Sparse Matrix Solver to proceed using the out-of-core memory mode. The total memory required by all processes = 805117 MB. The total physical memory that is available on the system = 15403 MB. Please decrease the model size, or run this model on another system with more physical memory.
      The same model ran successfully when the large deflections option is off.
      We have multiple base load cases and with large deflections 'on', some cases it is solving successfully but some it is throwing out the memory error.
      The error is very strange and it is asking for 805GB. System RAM is 16GB and in Hard-disk around 220 GB space is free.
      Kindly help me in resolving the issue.
    • Gary_S
      Hello
      This usually indicates the model is not constrained. Try adding some fixed supports to see if you can at least get a solution to see where the problem is.
    • mrife
      Hi @bharath_reddy1 also did the linear solve (large deflections turned off) use the Iterative solver? It requires about an order of magnitude less RAM than the Direct (Sparse) does. You can try specifying the solver type to be Iterative in the Details of the Analysis Settings, on the large deflection model, and see if it will solve or not.
      Mike
    • bharath_reddy1
      Hi Mike,
      Thank you for response. Next time we will use the option that you have suggested.
      However, I did a try with an increase tolerance to 2% and it solved all the load cases. Please see below screen shots of the analysis settings. Please advise any changes we can make to improve the solver time and maintaining the accuracy in results.
      Also advise on the help document where i can find the use of different options available in Newton-Raphson. Currently i have randomly selected as unsymmetrical
      Please see the image below on the Analysis model that i am trying to solve. It is having (a) basic load cases and (b) solution combinations in it. To solve basic loads cases - for each case it is taking more than 1 hour.
      This is the 1st time i am using Ansys to perform analysis for these kind of structures (We regularly use SACS for these king of global analysis). My experience in Ansys is just since last 45 days. I have developed ansys load cases and combinations based on past SACS experience. Please advise if there is any betterway to handle these things in Ansys so that the solution time can be reduced.
      Please let me know if you need analysis files for your review.
      Best regards Bharath
    • LUC ARNAUD KAKOU
      Hello I need your help for my simulation
      Sortie du solveur
       Ansys Mechanical Enterprise Academic Research
       |   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     |
       *         ANSYS MAPDL 2022 R2          LEGAL NOTICES          *
       * Copyright 1971-2022 Ansys, Inc.  All rights reserved.       *
       * Unauthorized use, distribution or duplication is            *
       * prohibited.                                                 *
       * Ansys is a registered trademark of Ansys, Inc. or its       *
       * subsidiaries in the United States or other countries.       *
       * See the Ansys, Inc. online documentation or the Ansys, Inc. *
       * documentation CD or online help for the complete Legal      *
       * Notice.                                                     *
       * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
       * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
       * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
       * The software products and documentation are furnished by    *
       * Ansys, Inc. or its subsidiaries under a software license    *
       * agreement that contains provisions concerning               *
       * non-disclosure, copying, length and nature of use,          *
       * compliance with exporting laws, warranties, disclaimers,    *
       * limitations of liability, and remedies, and other           *
       * provisions.  The software products and documentation may be *
       * used, disclosed, transferred, or copied only in accordance  *
       * with the terms and conditions of that software license      *
       * agreement.                                                  *
       * Ansys, Inc. is a UL registered                              *
       * ISO 9001:2015 company.                                      *
       * This product is subject to U.S. laws governing export and   *
       * re-export.                                                  *
       * For U.S. Government users, except as specifically granted   *
       * by the Ansys, Inc. software license agreement, the use,     *
       * duplication, or disclosure by the United States Government  *
       * is subject to restrictions stated in the Ansys, Inc.        *
       * software license agreement and FAR 12.212 (for non-DOD      *
       * licenses).                                                  *
       2022 R2
       Point Releases and Patches installed:
       ANSYS, Inc. License Manager 2022 R2
       Discovery 2022 R2
       SpaceClaim 2022 R2
       Ansys Sherlock 2022 R2
       Autodyn 2022 R2
       LS-DYNA 2022 R2
       CFD-Post only 2022 R2
       CFX (includes CFD-Post) 2022 R2
       Chemkin 2022 R2
       FENSAP-ICE 2022 R2
       Fluent (includes CFD-Post) 2022 R2
       Polyflow (includes CFD-Post) 2022 R2
       Forte (includes EnSight) 2022 R2
       TurboGrid 2022 R2
       ICEM CFD 2022 R2
       Aqwa 2022 R2
       optiSLang 2022 R2
       Additive 2022 R2
       Customization Files for User Programmable Features 2022 R2
       Mechanical Products 2022 R2
       Remote Solve Manager Standalone Services 2022 R2
       Viewer 2022 R2
       ACIS Geometry Interface 2022 R2
       AutoCAD Geometry Interface 2022 R2
       Catia, Version 4 Geometry Interface 2022 R2
       Catia, Version 5 Geometry Interface 2022 R2
       Catia, Version 6 Geometry Interface 2022 R2
       Creo Elements/Direct Modeling Geometry Interface 2022 R2
       Creo Parametric Geometry Interface 2022 R2
       Inventor Geometry Interface 2022 R2
       JTOpen Geometry Interface 2022 R2
       NX Geometry Interface 2022 R2
       Parasolid Geometry Interface  2022 R2
       Solid Edge Geometry Interface 2022 R2
       SOLIDWORKS Geometry Interface 2022 R2
                *****  MAPDL COMMAND LINE ARGUMENTS  *****
        BATCH MODE REQUESTED (-b)    = NOLIST
        INPUT FILE COPY MODE (-c)    = COPY
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     4 CORES REQUESTED
        INPUT FILE NAME              = D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617\dummy.dat
        OUTPUT FILE NAME             = D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617\solve.out
        START-UP FILE MODE           = NOREAD
        STOP FILE MODE               = NOREAD
       RELEASE= 2022 R2              BUILD= 22.2      UP20220516   VERSION=WINDOWS x64
       CURRENT JOBNAME=file0  20:09:04  MAY 15, 2023 CP=      0.031
       PARAMETER _DS_PROGRESS =     999.0000000
       /INPUT FILE= ds.dat  LINE=       0
       *** NOTE ***                            CP =       0.172   TIME= 20:09:04
       The /CONFIG,NOELDB command is not valid in a distributed memory
       parallel solution.  Command is ignored.
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  20.1511111
       TITLE=
       RIC--Thermique stationnaire (B5)
        ACT Extensions:
            LSDYNA, 2022.2
            5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
       /COM,     ANSYSMotion, 2022.2
            20180725-3f81-49eb-9f31-41364844c769, wbex
       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
        TYPE=STRI  DIMENSIONS=      248        1        1
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617\
       SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
       PARAMETER _WB_SOLVERFILES_DIR(1) = D:\LUC\VT4x4\VT4x4_RIC\RIC_files\dp0\SYS-22\MECH\
       SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
       PARAMETER _WB_USERFILES_DIR(1) = D:\LUC\VT4x4\VT4x4_RIC\RIC_files\user_files\
       --- Data in consistent uMKS units. See Solving Units in the help system for mor
       uMKS UNITS SPECIFIED FOR INTERNAL
        LENGTH      = MICROMETERS (um)
        MASS        = KILOGRAM (kg)
        TIME        = SECONDS (sec)
        TEMPERATURE = CELSIUS (C)
        TOFFSET     = 273.0
        FORCE       = MICRONEWTON (uN)
        HEAT        = PICOJOULES (pJ)
       INPUT  UNITS ARE ALSO SET TO UMKS
       *** MAPDL - ENGINEERING ANALYSIS SYSTEM  RELEASE 2022 R2          22.2     ***
       00000000  VERSION=WINDOWS x64   20:09:04  MAY 15, 2023 CP=      0.172
                ***** MAPDL ANALYSIS DEFINITION (PREP7) *****
       *********** Nodes for the whole assembly ***********
       *********** Elements for Body 1 "TUBE1" ***********
       *********** Elements for Body 2 "TUBE2" ***********
       *********** Elements for Body 3 "TUBE3" ***********
       *********** Elements for Body 4 "TUBE4" ***********
       *********** Elements for Body 5 "TUBE5" ***********
       *********** Elements for Body 6 "TUBE6" ***********
       *********** Elements for Body 7 "TUBE7" ***********
       *********** Elements for Body 8 "TUBE8" ***********
       *********** Elements for Body 9 "TUBE9" ***********
       *********** Elements for Body 10 "TUBE10" ***********
       *********** Elements for Body 11 "TUBE11" ***********
       *********** Elements for Body 12 "TUBE12" ***********
       *********** Elements for Body 13 "TUBE13" ***********
       *********** Elements for Body 14 "TUBE15" ***********
       *********** Elements for Body 15 "TUBE14" ***********
       *********** Elements for Body 16 "TUBE16" ***********
       *********** Elements for Body 17 "TUBE17" ***********
       *********** Elements for Body 18 "TUBE18" ***********
       *********** Elements for Body 19 "TUBE19" ***********
       *********** Elements for Body 20 "TUBE20" ***********
       *********** Elements for Body 21 "TUBE21" ***********
       *********** Elements for Body 22 "TUBE22" ***********
       *********** Elements for Body 23 "TUBE23" ***********
       *********** Elements for Body 24 "TUBE24" ***********
       *********** Elements for Body 25 "TUBE25" ***********
       *********** Elements for Body 26 "TUBE26" ***********
       *********** Elements for Body 27 "TUBE27" ***********
       *********** Elements for Body 28 "TUBE28" ***********
       *********** Elements for Body 29 "TUBE29" ***********
       *********** Elements for Body 30 "TUBE30" ***********
       *********** Elements for Body 31 "TUBE31" ***********
       *********** Elements for Body 32 "TUBE32" ***********
       *********** Elements for Body 33 "TUBE33" ***********
       *********** Elements for Body 34 "TUBE34" ***********
       *********** Elements for Body 35 "TUBE35" ***********
       *********** Elements for Body 36 "TUBE36" ***********
       *********** Elements for Body 37 "TUBE37" ***********
       *********** Elements for Body 38 "EMC" ***********
       *********** Elements for Body 39 "GaN" ***********
       *********** Elements for Body 40 "SiC" ***********
       *********** Elements for Body 41 "AuSIC" ***********
       *********** Elements for Body 42 "VIAHOLE1" ***********
       *********** Elements for Body 43 "VIAHOLE2" ***********
       *********** Elements for Body 44 "VIAHOLE3" ***********
       *********** Elements for Body 45 "VIAHOLE4" ***********
       *********** Elements for Body 46 "VIAHOLE5" ***********
       *********** Elements for Body 47 "VIAHOLE6" ***********
       *********** Elements for Body 48 "VIAHOLE7" ***********
       *********** Elements for Body 49 "VIAHOLE8" ***********
       *********** Elements for Body 50 "VIAHOLE9" ***********
       *********** Elements for Body 51 "VIAHOLE10" ***********
       *********** Elements for Body 52 "VIAHOLE11" ***********
       *********** Elements for Body 53 "VIAHOLE13" ***********
       *********** Elements for Body 54 "VIAHOLE14" ***********
       *********** Elements for Body 55 "VIAHOLE15" ***********
       *********** Elements for Body 56 "VIAHOLE16" ***********
       *********** Elements for Body 57 "VIAHOLE17" ***********
       *********** Elements for Body 58 "VIAHOLE18" ***********
       *********** Elements for Body 59 "VIAHOLE19" ***********
       *********** Elements for Body 60 "VIAHOLE20" ***********
       *********** Elements for Body 61 "VIAHOLE21" ***********
       *********** Elements for Body 62 "VIAHOLE22" ***********
       *********** Elements for Body 63 "VIAHOLE23" ***********
       *********** Elements for Body 64 "VIAHOLE24" ***********
       *********** Elements for Body 65 "VIAHOLE25" ***********
       *********** Elements for Body 66 "VIAHOLE26" ***********
       *********** Elements for Body 67 "VIAHOLE27" ***********
       *********** Elements for Body 68 "VIAHOLE28" ***********
       *********** Elements for Body 69 "VIAHOLE29" ***********
       *********** Elements for Body 70 "VIAHOLE30" ***********
       *********** Elements for Body 71 "VIAHOLE31" ***********
       *********** Elements for Body 72 "VIAHOLE32" ***********
       *********** Elements for Body 73 "VIAHOLE33" ***********
       *********** Elements for Body 74 "VIAHOLE34" ***********
       *********** Elements for Body 75 "VIAHOLE35" ***********
       *********** Elements for Body 76 "VIAHOLE36" ***********
       *********** Elements for Body 77 "VIAHOLE37" ***********
       *********** Elements for Body 78 "VIAHOLE38" ***********
       *********** Elements for Body 79 "VIAHOLE39" ***********
       *********** Elements for Body 80 "VIAHOLE40" ***********
       *********** Elements for Body 81 "VIAHOLE41" ***********
       *********** Elements for Body 82 "VIAHOLE42" ***********
       *********** Elements for Body 83 "VIAHOLE43" ***********
       *********** Elements for Body 84 "VIAHOLE44" ***********
       *********** Elements for Body 85 "VIAHOLE45" ***********
       *********** Elements for Body 86 "VIAHOLE12" ***********
       *********** Elements for Body 87 "UBMH1" ***********
       *********** Elements for Body 88 "UBMH2" ***********
       *********** Elements for Body 89 "UBMH3" ***********
       *********** Elements for Body 90 "UBMH4" ***********
       *********** Elements for Body 91 "UBMH5" ***********
       *********** Elements for Body 92 "UBMH6" ***********
       *********** Elements for Body 93 "UBMH7" ***********
       *********** Elements for Body 94 "UBMH8" ***********
       *********** Elements for Body 95 "UBMH9" ***********
       *********** Elements for Body 96 "UBMH10" ***********
       *********** Elements for Body 97 "UBMH11" ***********
       *********** Elements for Body 98 "UBMH12" ***********
       *********** Elements for Body 99 "UBMH13" ***********
       *********** Elements for Body 100 "UBMH14" ***********
       *********** Elements for Body 101 "UBMH15" ***********
       *********** Elements for Body 102 "UBMH16" ***********
       *********** Elements for Body 103 "UBMH17" ***********
       *********** Elements for Body 104 "UBMH18" ***********
       *********** Elements for Body 105 "UBMH19" ***********
       *********** Elements for Body 106 "UBMH20" ***********
       *********** Elements for Body 107 "UBMH21" ***********
       *********** Elements for Body 108 "UBMH22" ***********
       *********** Elements for Body 109 "UBMH23" ***********
       *********** Elements for Body 110 "UBMH24" ***********
       *********** Elements for Body 111 "UBMH25" ***********
       *********** Elements for Body 112 "UBMH26" ***********
       *********** Elements for Body 113 "UBMH27" ***********
       *********** Elements for Body 114 "UBMH28" ***********
       *********** Elements for Body 115 "UBMH29" ***********
       *********** Elements for Body 116 "UBMH30" ***********
       *********** Elements for Body 117 "UBMH31" ***********
       *********** Elements for Body 118 "UBMH32" ***********
       *********** Elements for Body 119 "BILLES1" ***********
       *********** Elements for Body 120 "BILLES2" ***********
       *********** Elements for Body 121 "BILLES3" ***********
       *********** Elements for Body 122 "BILLES4" ***********
       *********** Elements for Body 123 "BILLES5" ***********
       *********** Elements for Body 124 "BILLES6" ***********
       *********** Elements for Body 125 "BILLES7" ***********
       *********** Elements for Body 126 "BILLES8" ***********
       *********** Elements for Body 127 "BILLES9" ***********
       *********** Elements for Body 128 "BILLES10" ***********
       *********** Elements for Body 129 "BILLES11" ***********
       *********** Elements for Body 130 "BILLES12" ***********
       *********** Elements for Body 131 "BILLES13" ***********
       *********** Elements for Body 132 "BILLES14" ***********
       *********** Elements for Body 133 "BILLES15" ***********
       *********** Elements for Body 134 "BILLES16" ***********
       *********** Elements for Body 135 "BILLES17" ***********
       *********** Elements for Body 136 "BILLES18" ***********
       *********** Elements for Body 137 "BILLES19" ***********
       *********** Elements for Body 138 "BILLES20" ***********
       *********** Elements for Body 139 "BILLES21" ***********
       *********** Elements for Body 140 "BILLES22" ***********
       *********** Elements for Body 141 "BILLES23" ***********
       *********** Elements for Body 142 "BILLES24" ***********
       *********** Elements for Body 143 "BILLES25" ***********
       *********** Elements for Body 144 "BILLES26" ***********
       *********** Elements for Body 145 "BILLES27" ***********
       *********** Elements for Body 146 "BILLES28" ***********
       *********** Elements for Body 147 "BILLES29" ***********
       *********** Elements for Body 148 "BILLES30" ***********
       *********** Elements for Body 149 "BILLES31" ***********
       *********** Elements for Body 150 "BILLES32" ***********
       *********** Elements for Body 151 "RDL1" ***********
       *********** Elements for Body 152 "RDL2" ***********
       *********** Elements for Body 153 "RDL3" ***********
       *********** Elements for Body 154 "RDL4" ***********
       *********** Elements for Body 155 "RDL5" ***********
       *********** Elements for Body 156 "RDL6" ***********
       *********** Elements for Body 157 "RDL7" ***********
       *********** Elements for Body 158 "RDL8" ***********
       *********** Elements for Body 159 "RDL9" ***********
       *********** Elements for Body 160 "RDL10" ***********
       *********** Elements for Body 161 "RDL11" ***********
       *********** Elements for Body 162 "RDL12" ***********
       *********** Elements for Body 163 "RDL13" ***********
       *********** Elements for Body 164 "RDL14" ***********
       *********** Elements for Body 165 "RDL15" ***********
       *********** Elements for Body 166 "RDL16" ***********
       *********** Elements for Body 167 "RDL17" ***********
       *********** Elements for Body 168 "RDL18" ***********
       *********** Elements for Body 169 "RDL19" ***********
       *********** Elements for Body 170 "RDL20" ***********
       *********** Elements for Body 171 "RDL21" ***********
       *********** Elements for Body 172 "RDL22" ***********
       *********** Elements for Body 173 "RDL23" ***********
       *********** Elements for Body 174 "RDL24" ***********
       *********** Elements for Body 175 "RDL25" ***********
       *********** Elements for Body 176 "RDL26" ***********
       *********** Elements for Body 177 "RDL27" ***********
       *********** Elements for Body 178 "RDL28" ***********
       *********** Elements for Body 179 "RDL29" ***********
       *********** Elements for Body 180 "RDL30" ***********
       *********** Elements for Body 181 "RDL31" ***********
       *********** Elements for Body 182 "RDL32" ***********
       *********** Elements for Body 183 "RDL33" ***********
       *********** Elements for Body 184 "RDL34" ***********
       *********** Elements for Body 185 "RDL35" ***********
       *********** Elements for Body 186 "RDL36" ***********
       *********** Elements for Body 187 "METTALISATION108" ***********
       *********** Elements for Body 188 "METTALISATION1" ***********
       *********** Elements for Body 189 "METTALISATION2" ***********
       *********** Elements for Body 190 "METTALISATION3" ***********
       *********** Elements for Body 191 "METTALISATION4" ***********
       *********** Elements for Body 192 "METTALISATION5" ***********
       *********** Elements for Body 193 "METTALISATION6" ***********
       *********** Elements for Body 194 "METTALISATION7" ***********
       *********** Elements for Body 195 "PONTTRANSISTOR1" ***********
       *********** Elements for Body 196 "METTALISATION9" ***********
       *********** Elements for Body 197 "METTALISATION10" ***********
       *********** Elements for Body 198 "METTALISATION11" ***********
       *********** Elements for Body 199 "METTALISATION12" ***********
       *********** Elements for Body 200 "METTALISATION13" ***********
       *********** Elements for Body 201 "PONTTRANSISTOR2" ***********
       *********** Elements for Body 202 "METTALISATION15" ***********
       *********** Elements for Body 203 "METTALISATION16" ***********
       *********** Elements for Body 204 "METTALISATION17" ***********
       *********** Elements for Body 205 "METTALISATION18" ***********
       *********** Elements for Body 206 "METTALISATION19" ***********
       *********** Elements for Body 207 "METTALISATION20" ***********
       *********** Elements for Body 208 "METTALISATION21" ***********
       *********** Elements for Body 209 "METTALISATION22" ***********
       *********** Elements for Body 210 "METTALISATION23" ***********
       *********** Elements for Body 211 "METTALISATION24" ***********
       *********** Elements for Body 212 "METTALISATION25" ***********
       *********** Elements for Body 213 "METTALISATION26" ***********
       *********** Elements for Body 214 "METTALISATION27" ***********
       *********** Elements for Body 215 "METTALISATION28" ***********
       *********** Elements for Body 216 "METTALISATION29" ***********
       *********** Elements for Body 217 "METTALISATION30" ***********
       *********** Elements for Body 218 "METTALISATION31" ***********
       *********** Elements for Body 219 "METTALISATION32" ***********
       *********** Elements for Body 220 "METTALISATION33" ***********
       *********** Elements for Body 221 "METTALISATION34" ***********
       *********** Elements for Body 222 "METTALISATION35" ***********
       *********** Elements for Body 223 "METTALISATION36" ***********
       *********** Elements for Body 224 "METTALISATION37" ***********
       *********** Elements for Body 225 "METTALISATION38" ***********
       *********** Elements for Body 226 "METTALISATION39" ***********
       *********** Elements for Body 227 "METTALISATION40" ***********
       *********** Elements for Body 228 "METTALISATION41" ***********
       *********** Elements for Body 229 "METTALISATION42" ***********
       *********** Elements for Body 230 "METTALISATION43" ***********
       *********** Elements for Body 231 "METTALISATION44" ***********
       *********** Elements for Body 232 "METTALISATION45" ***********
       *********** Elements for Body 233 "METTALISATION46" ***********
       *********** Elements for Body 234 "METTALISATION47" ***********
       *********** Elements for Body 235 "METTALISATION48" ***********
       *********** Elements for Body 236 "METTALISATION49" ***********
       *********** Elements for Body 237 "METTALISATION50" ***********
       *********** Elements for Body 238 "METTALISATION51" ***********
       *********** Elements for Body 239 "METTALISATION52" ***********
       *********** Elements for Body 240 "METTALISATION53" ***********
       *********** Elements for Body 241 "METTALISATION54" ***********
       *********** Elements for Body 242 "METTALISATION55" ***********
       *********** Elements for Body 243 "METTALISATION56" ***********
       *********** Elements for Body 244 "METTALISATION57" ***********
       *********** Elements for Body 245 "METTALISATION58" ***********
       *********** Elements for Body 246 "SIN11" ***********
       *********** Elements for Body 247 "SIN221" ***********
       *********** Elements for Body 248 "SIN211" ***********
       *********** Elements for Body 249 "GRILLE11_8x60_m" ***********
       *********** Elements for Body 250 "GRILLE12_8x60_m" ***********
       *********** Elements for Body 251 "GRILLE13_8x60_m" ***********
       *********** Elements for Body 252 "GRILLE14_8x60_m" ***********
       *********** Elements for Body 253 "GRILLE15_8x60_m" ***********
       *********** Elements for Body 254 "GRILLE16_8x60_m" ***********
       *********** Elements for Body 255 "GRILLE17_8x60_m" ***********
       *********** Elements for Body 256 "GRILLE18_8x60_m" ***********
       *********** Elements for Body 257 "FIELDPLATE1" ***********
       *********** Elements for Body 258 "FIELDPLATE2" ***********
       *********** Elements for Body 259 "FIELDPLATE3" ***********
       *********** Elements for Body 260 "FIELDPLATE4" ***********
       *********** Elements for Body 261 "FIELDPLATE5" ***********
       *********** Elements for Body 262 "FIELDPLATE6" ***********
       *********** Elements for Body 263 "FIELDPLATE7" ***********
       *********** Elements for Body 264 "FIELDPLATE8" ***********
       *********** Elements for Body 265 "FIELDPLATE9" ***********
       *********** Elements for Body 266 "FIELDPLATE10" ***********
       *********** Elements for Body 267 "FIELDPLATE11" ***********
       *********** Elements for Body 268 "FIELDPLATE12" ***********
       *********** Elements for Body 269 "FIELDPLATE13" ***********
       *********** Elements for Body 270 "FIELDPLATE14" ***********
       *********** Elements for Body 271 "FIELDPLATE15" ***********
       *********** Elements for Body 272 "FIELDPLATE16" ***********
       *********** Elements for Body 273 "FIELDPLATE17" ***********
       *********** Elements for Body 274 "FIELDPLATE18" ***********
       *********** Elements for Body 275 "FIELDPLATE19" ***********
       *********** Elements for Body 276 "FIELDPLATE20" ***********
       *********** Elements for Body 277 "FIELDPLATE21" ***********
       *********** Elements for Body 278 "FIELDPLATE22" ***********
       *********** Elements for Body 279 "FIELDPLATE23" ***********
       *********** Elements for Body 280 "FIELDPLATE24" ***********
       *********** Elements for Body 281 "BCB1" ***********
       *********** Elements for Body 282 "BCB2" ***********
       *********** Elements for Body 283 "BCB3" ***********
       *********** Elements for Body 284 "METTALISATION9" ***********
       *********** Elements for Body 285 "METTALISATION24" ***********
       *********** Elements for Body 286 "METTALISATION36" ***********
       *********** Elements for Body 287 "METTALISATION24" ***********
       *********** Elements for Body 288 "SIN12" ***********
       *********** Elements for Body 289 "SIN222" ***********
       *********** Elements for Body 290 "SIN212" ***********
       *********** Elements for Body 291 "SIN13" ***********
       *********** Elements for Body 292 "SIN223" ***********
       *********** Elements for Body 293 "SIN213" ***********
       *********** Elements for Body 294 "SIN14" ***********
       *********** Elements for Body 295 "SIN224" ***********
       *********** Elements for Body 296 "SIN214" ***********
       *********** Elements for Body 297 "SIN15" ***********
       *********** Elements for Body 298 "SIN225" ***********
       *********** Elements for Body 299 "SIN215" ***********
       *********** Elements for Body 300 "SIN16" ***********
       *********** Elements for Body 301 "SIN226" ***********
       *********** Elements for Body 302 "SIN216" ***********
       *********** Elements for Body 303 "SIN17" ***********
       *********** Elements for Body 304 "SIN227" ***********
       *********** Elements for Body 305 "SIN217" ***********
       *********** Elements for Body 306 "SIN18" ***********
       *********** Elements for Body 307 "SIN228" ***********
       *********** Elements for Body 308 "SIN218" ***********
       *********** Elements for Body 309 "GRILLE221_8x60_m" ***********
       *********** Elements for Body 310 "GRILLE222_8x60_m" ***********
       *********** Elements for Body 311 "GRILLE223_8x60_m" ***********
       *********** Elements for Body 312 "GRILLE224_8x60_m" ***********
       *********** Elements for Body 313 "GRILLE225_8x60_m" ***********
       *********** Elements for Body 314 "GRILLE226_8x60_m" ***********
       *********** Elements for Body 315 "GRILLE227_8x60_m" ***********
       *********** Elements for Body 316 "GRILLE228_8x60_m" ***********
       *********** Elements for Body 317 "GRILLE211_8x60_m" ***********
       *********** Elements for Body 318 "GRILLE212_8x60_m" ***********
       *********** Elements for Body 319 "GRILLE213_8x60_m" ***********
       *********** Elements for Body 320 "GRILLE214_8x60_m" ***********
       *********** Elements for Body 321 "GRILLE215_8x60_m" ***********
       *********** Elements for Body 322 "GRILLE216_8x60_m" ***********
       *********** Elements for Body 323 "GRILLE217_8x60_m" ***********
       *********** Elements for Body 324 "GRILLE218_8x60_m" ***********
       *********** Send User Defined Coordinate System(s) ***********
       *********** Send Materials ***********
       *********** Send Named Selection as Element Component ***********
       *********** Send Named Selection as Node Component ***********
       *********** Define Temperature Constraint ***********
       *********** Create "Débit de chaleur" ***********
       *********** Create "Débit de chaleur 2" ***********
       *********** Create "Débit de chaleur 3" ***********
       ***************** Define Uniform Initial temperature ***************
       ***** ROUTINE COMPLETED *****  CP =       627.406
       --- Number of total nodes = 12708931
       --- Number of contact elements = 112943
       --- Number of spring elements = 0
       --- Number of bearing elements = 0
       --- Number of solid elements = 74133495
       --- Number of condensed parts = 0
       --- Number of total elements = 74246438
       *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  20.2377778
       *************************    SOLUTION       ********************************
       *****  MAPDL SOLUTION ROUTINE  *****
       PERFORM A STATIC ANALYSIS
        THIS WILL BE A NEW ANALYSIS
       USE PRECONDITIONED CONJUGATE GRADIENT SOLVER
        CONVERGENCE TOLERANCE = 1.00000E-08
        MAXIMUM ITERATION     = NumNode*DofPerNode*  1.0000
       CONTACT INFORMATION PRINTOUT LEVEL       1
       DO NOT SAVE ANY RESTART FILES AT ALL
       DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
       DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
       ******************* SOLVE FOR LS 1 OF 1 ****************
       SPECIFIED CONSTRAINT TEMP FOR PICKED NODES
       REAL=  25.0000000       IMAG=  0.00000000
       SELECT       FOR ITEM=TYPE COMPONENT=
        IN RANGE       325 TO        325 STEP          1
            37636  ELEMENTS (OF   74246438  DEFINED) SELECTED BY  ESEL  COMMAND.
       SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
            28235 NODES (OF   12708931  DEFINED) SELECTED FROM
          37636 SELECTED ELEMENTS BY NSLE COMMAND.
       GENERATE SURFACE LOAD HFLU ON SURFACE DEFINED BY ALL SELECTED NODES
       VALUE =  2.430555556E+10
       NUMBER OF HFLU ELEMENT FACE LOADS STORED =      37636
        IN RANGE       326 TO        326 STEP          1
            37657  ELEMENTS (OF   74246438  DEFINED) SELECTED BY  ESEL  COMMAND.
            28249 NODES (OF   12708931  DEFINED) SELECTED FROM
          37657 SELECTED ELEMENTS BY NSLE COMMAND.
       NUMBER OF HFLU ELEMENT FACE LOADS STORED =      37657
        IN RANGE       327 TO        327 STEP          1
            37650  ELEMENTS (OF   74246438  DEFINED) SELECTED BY  ESEL  COMMAND.
            28244 NODES (OF   12708931  DEFINED) SELECTED FROM
          37650 SELECTED ELEMENTS BY NSLE COMMAND.
       NUMBER OF HFLU ELEMENT FACE LOADS STORED =      37650
       ALL SELECT   FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO   12708931 STEP          1
         12708931  NODES (OF   12708931  DEFINED) SELECTED BY NSEL  COMMAND.
       ALL SELECT   FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO   85543138 STEP          1
         74246438  ELEMENTS (OF   74246438  DEFINED) SELECTED BY  ESEL  COMMAND.
       PRINTOUT RESUMED BY /GOP
       USE AUTOMATIC TIME STEPPING THIS LOAD STEP
       USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
       FOR AUTOMATIC TIME STEPPING:
         USE     10 SUBSTEPS AS A MAXIMUM
         USE      1 SUBSTEPS AS A MINIMUM
       TIME=  1.0000
       ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
         FOR ALL APPLICABLE ENTITIES
       WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE FFLU ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       CONVERGENCE ON HEAT BASED ON THE NORM OF THE N-R LOAD
         WITH A TOLERANCE OF 0.1000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E+07
         USING THE L2 NORM (CHECK THE SRSS VALUE)
       *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
       *IF  ANSINTER_                         ( =   0.00000     )  NE
            0                                 ( =   0.00000     )  THEN
       *ENDIF
       *** NOTE ***                            CP =    1202.906   TIME= 20:18:39
       The automatic domain decomposition logic has selected the MESH domain
       decomposition method with 4 processes per solution.
       *****  MAPDL SOLVE    COMMAND  *****
       *** WARNING ***                         CP =    1230.906   TIME= 20:18:47
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** NOTE ***                            CP =    1724.547   TIME= 20:21:28
       The model data was checked and warning messages were found.
        Please review output or errors file (
       D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617\file0.err ) for these
       warning messages.
       00000000  VERSION=WINDOWS x64   20:21:45  MAY 15, 2023 CP=   1741.766
                             S O L U T I O N   O P T I O N S
         PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
         DEGREES OF FREEDOM. . . . . . TEMP
         ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
         OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
         EQUATION SOLVER OPTION. . . . . . . . . . . . .PCG
            TOLERANCE. . . . . . . . . . . . . . . . . . 1.00000E-08
         NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
         GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
       *** WARNING ***                         CP =    1783.016   TIME= 20:22:27
       Material number 325 (used by element 85430196) should normally have at
       least one MP or one TB type command associated with it.  Output of
       energy by material may not be available.
       *** NOTE ***                            CP =    1822.875   TIME= 20:22:40
       The step data was checked and warning messages were found.
       warning messages.
       This nonlinear analysis defaults to using the full Newton-Raphson
       solution procedure.  This can be modified using the NROPT command.
       The conditions for direct assembly have been met.  No .emat or .erot
       files will be produced.
           D I S T R I B U T E D   D O M A I N   D E C O M P O S E R
        ...Number of elements: 74246438
        ...Number of nodes:    12708931
        ...Decompose to 4 CPU domains
        ...Element load balance ratio =     1.001
                            L O A D   S T E P   O P T I O N S
         LOAD STEP NUMBER. . . . . . . . . . . . . . . .     1
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  1.0000
         AUTOMATIC TIME STEPPING . . . . . . . . . . . .    ON
            INITIAL NUMBER OF SUBSTEPS . . . . . . . . .     1
            MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .    10
            MINIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
         MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .    15
         STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .    NO
         TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
         NODAL DOF SOLUTION LIMIT. . . . . . . . . . . . 0.10000E+10
         CONVERGENCE CONTROLS
            LABEL   REFERENCE    TOLERANCE  NORM     MINREF
             HEAT    0.000       0.1000E-02   2     0.1000E+07
         PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
         DATABASE OUTPUT CONTROLS
            ITEM     FREQUENCY   COMPONENT
             ALL       NONE
            NSOL        ALL
            RSOL        ALL
            EANG        ALL
            VENG        ALL
            FFLU        ALL
            CONT        ALL
       SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
       *** NOTE ***                            CP =    2625.219   TIME= 20:30:56
       The PCG solver has automatically set the level of difficulty for this
       model to 1.
                  **** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
        CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
        TOTAL MASS =  0.73731E-05
                                 MOM. OF INERTIA         MOM. OF INERTIA
        CENTER OF MASS            ABOUT ORIGIN        ABOUT CENTER OF MASS
        XC =   2376.5          IXX =    52.55          IXX =    12.33
        YC =   2335.5          IYY =    53.98          IYY =    12.33
        ZC =  -1.0047          IZZ =    106.4          IZZ =    24.54
                               IXY =   -40.80          IXY =   0.1214
                               IYZ =   0.3993E-02      IYZ =  -0.1331E-01
                               IZX =   0.3033E-01      IZX =   0.1272E-01
        *** MASS SUMMARY BY ELEMENT TYPE ***
        TYPE      MASS
           1  0.593948E-08
           2  0.593835E-08
           3  0.593856E-08
           4  0.593984E-08
           5  0.593828E-08
           6  0.593995E-08
           7  0.593848E-08
           8  0.593866E-08
           9  0.593821E-08
          10  0.593893E-08
          11  0.593780E-08
          12  0.593792E-08
          13  0.593783E-08
          14  0.593911E-08
          15  0.594010E-08
          16  0.593867E-08
          17  0.593881E-08
          18  0.593844E-08
          19  0.593743E-08
          20  0.594043E-08
          21  0.593973E-08
          22  0.593826E-08
          23  0.594147E-08
          24  0.593877E-08
          25  0.593704E-08
          26  0.593912E-08
          27  0.593987E-08
          28  0.593864E-08
          29  0.593891E-08
          30  0.593710E-08
          31  0.593821E-08
          32  0.593797E-08
          33  0.593951E-08
          34  0.594101E-08
          35  0.594054E-08
          36  0.593826E-08
          37  0.593788E-08
          38  0.832536E-08
          39  0.141638E-06
          40  0.307863E-05
          41  0.118898E-05
          42  0.967688E-09
          43  0.967570E-09
          44  0.967813E-09
          45  0.967979E-09
          46  0.967715E-09
          47  0.967762E-09
          48  0.967783E-09
          49  0.967920E-09
          50  0.967712E-09
          51  0.967652E-09
          52  0.967830E-09
          53  0.967307E-09
          54  0.967649E-09
          55  0.968013E-09
          56  0.967766E-09
          57  0.967794E-09
          58  0.967634E-09
          59  0.967848E-09
          60  0.967628E-09
          61  0.967678E-09
          62  0.967781E-09
          63  0.967929E-09
          64  0.968000E-09
          65  0.967715E-09
          66  0.967505E-09
          67  0.967692E-09
          68  0.968285E-09
          69  0.967892E-09
          70  0.967485E-09
          71  0.967644E-09
          72  0.967858E-09
          73  0.967774E-09
          74  0.967501E-09
          75  0.967775E-09
          76  0.967626E-09
          77  0.967816E-09
          78  0.967880E-09
          79  0.967796E-09
          80  0.967626E-09
          81  0.967779E-09
          82  0.967789E-09
          83  0.967738E-09
          84  0.967750E-09
          85  0.967971E-09
          86  0.967813E-09
          87  0.127245E-08
          88  0.127245E-08
          89  0.127245E-08
          90  0.127245E-08
          91  0.127245E-08
          92  0.127245E-08
          93  0.127245E-08
          94  0.127245E-08
          95  0.127245E-08
          96  0.127245E-08
          97  0.127245E-08
          98  0.127245E-08
          99  0.127245E-08
         100  0.127245E-08
         101  0.127245E-08
         102  0.127245E-08
         103  0.127245E-08
         104  0.127245E-08
         105  0.127245E-08
         106  0.127245E-08
         107  0.127245E-08
         108  0.127245E-08
         109  0.127245E-08
         110  0.127245E-08
         111  0.127245E-08
         112  0.127245E-08
         113  0.127245E-08
         114  0.127245E-08
         115  0.127245E-08
         116  0.127245E-08
         117  0.127245E-08
         118  0.127245E-08
         119  0.731910E-07
         120  0.731539E-07
         121  0.731672E-07
         122  0.731993E-07
         123  0.731650E-07
         124  0.731552E-07
         125  0.731995E-07
         126  0.731954E-07
         127  0.731884E-07
         128  0.731385E-07
         129  0.731970E-07
         130  0.731763E-07
         131  0.731666E-07
         132  0.731327E-07
         133  0.732463E-07
         134  0.731206E-07
         135  0.731114E-07
         136  0.732190E-07
         137  0.731302E-07
         138  0.730509E-07
         139  0.731294E-07
         140  0.732181E-07
         141  0.731502E-07
         142  0.731972E-07
         143  0.731402E-07
         144  0.731778E-07
         145  0.731636E-07
         146  0.731278E-07
         147  0.731652E-07
         148  0.731642E-07
         149  0.731946E-07
         150  0.731683E-07
         151  0.939560E-09
         152  0.607560E-09
         153  0.149400E-09
         154  0.149400E-09
         155  0.244409E-08
         156  0.157738E-08
         157  0.707361E-08
         158  0.557317E-08
         159  0.284570E-08
         160  0.157738E-08
         161  0.374954E-08
         162  0.281603E-08
         163  0.157738E-08
         164  0.704385E-08
         165  0.304586E-08
         166  0.292299E-08
         167  0.317526E-08
         168  0.286444E-08
         169  0.319589E-08
         170  0.291424E-08
         171  0.157738E-08
         172  0.340494E-08
         173  0.273300E-08
         174  0.270589E-08
         175  0.338950E-08
         176  0.415807E-08
         177  0.545091E-08
         178  0.373570E-08
         179  0.157738E-08
         180  0.293416E-08
         181  0.320559E-08
         182  0.586957E-08
         183  0.319166E-08
         184  0.279430E-08
         185  0.425343E-08
         186  0.288393E-08
         187  0.104457E-08
         188  0.826812E-10
         189  0.104462E-08
         190  0.826812E-10
         191  0.106551E-08
         192  0.243214E-09
         193  0.988481E-08
         194  0.211582E-08
         195  0.163792E-08
         196  0.143143E-08
         197  0.801616E-08
         198  0.672412E-10
         199  0.690022E-10
         200  0.340436E-09
         201  0.283336E-08
         202  0.232492E-08
         203  0.142088E-08
         204  0.183791E-08
         205  0.338836E-09
         206  0.228637E-08
         207  0.273610E-08
         208  0.803599E-08
         209  0.662222E-09
         210  0.667626E-09
         211  0.154709E-09
         212  0.322696E-10
         213  0.322696E-10
         214  0.322696E-10
         215  0.322696E-10
         216  0.312820E-08
         217  0.155479E-08
         218  0.111233E-08
         219  0.156931E-08
         220  0.209389E-08
         221  0.206400E-08
         222  0.222635E-08
         223  0.311395E-08
         224  0.186863E-08
         225  0.222635E-08
         226  0.126579E-08
         227  0.751465E-09
         228  0.222635E-08
         229  0.182587E-08
         230  0.181825E-08
         231  0.222635E-08
         232  0.430100E-08
         233  0.185602E-08
         234  0.185602E-08
         235  0.222635E-08
         236  0.185602E-08
         237  0.949131E-08
         238  0.181347E-08
         239  0.222635E-08
         240  0.342113E-08
         241  0.322696E-10
         242  0.322696E-10
         243  0.322696E-10
         244  0.322696E-10
         245  0.312820E-08
         246  0.709863E-12
         247  0.709863E-12
         248  0.709863E-12
         249  0.613740E-13
         250  0.613740E-13
         251  0.613740E-13
         252  0.613740E-13
         253  0.613740E-13
         254  0.613740E-13
         255  0.613740E-13
         256  0.613740E-13
         257  0.157675E-11
         258  0.157675E-11
         259  0.157675E-11
         260  0.157675E-11
         261  0.157675E-11
         262  0.157675E-11
         263  0.157675E-11
         264  0.157675E-11
         265  0.157675E-11
         266  0.157675E-11
         267  0.157675E-11
         268  0.157675E-11
         269  0.157675E-11
         270  0.157675E-11
         271  0.157675E-11
         272  0.157675E-11
         273  0.157675E-11
         274  0.157675E-11
         275  0.157675E-11
         276  0.157675E-11
         277  0.157675E-11
         278  0.157675E-11
         279  0.157675E-11
         280  0.157675E-11
         281  0.129444E-08
         282  0.129444E-08
         283  0.129444E-08
         284  0.769403E-07
         285  0.173158E-08
         286  0.227649E-08
         287  0.134216E-08
         288  0.709863E-12
         289  0.709863E-12
         290  0.709863E-12
         291  0.709863E-12
         292  0.709863E-12
         293  0.709863E-12
         294  0.709863E-12
         295  0.709863E-12
         296  0.709863E-12
         297  0.709863E-12
         298  0.709863E-12
         299  0.709863E-12
         300  0.709863E-12
         301  0.709863E-12
         302  0.709863E-12
         303  0.709863E-12
         304  0.709863E-12
         305  0.709863E-12
         306  0.709863E-12
         307  0.709863E-12
         308  0.709863E-12
         309  0.613740E-13
         310  0.613740E-13
         311  0.613740E-13
         312  0.613740E-13
         313  0.613740E-13
         314  0.613740E-13
         315  0.613740E-13
         316  0.613740E-13
         317  0.613740E-13
         318  0.613740E-13
         319  0.613740E-13
         320  0.613740E-13
         321  0.613740E-13
         322  0.613740E-13
         323  0.613740E-13
         324  0.613740E-13
       Range of element maximum matrix coefficients in global coordinates
       Maximum = 2.088366701E+12 at element 34000791.
       Minimum = 27440.8025 at element 47906535.
         *** ELEMENT MATRIX FORMULATION TIMES
           TYPE    NUMBER   ENAME      TOTAL CP  AVE CP
              1     14759  SOLID278      0.234   0.000016
              2     14765  SOLID278      0.234   0.000016
              3     14808  SOLID278      0.266   0.000018
              4     14930  SOLID278      0.219   0.000015
              5     14480  SOLID278      0.312   0.000022
              6     14559  SOLID278      0.234   0.000016
              7     14522  SOLID278      0.219   0.000015
              8     14490  SOLID278      0.406   0.000028
              9     14436  SOLID278      0.328   0.000023
             10     14526  SOLID278      0.203   0.000014
             11     14541  SOLID278      0.281   0.000019
             12     14675  SOLID278      0.281   0.000019
             13     14796  SOLID278      0.484   0.000033
             14     14872  SOLID278      0.406   0.000027
             15     14915  SOLID278      0.234   0.000016
             16     14676  SOLID278      0.375   0.000026
             17     14806  SOLID278      0.250   0.000017
             18     14876  SOLID278      0.516   0.000035
             19     14541  SOLID278      0.234   0.000016
             20     14956  SOLID278      0.344   0.000023
             21     14739  SOLID278      0.250   0.000017
             22     15116  SOLID278      0.172   0.000011
             23     14758  SOLID278      0.234   0.000016
             24     14701  SOLID278      0.281   0.000019
             25     14322  SOLID278      0.219   0.000015
             26     14636  SOLID278      0.250   0.000017
             27     14738  SOLID278      0.250   0.000017
             28     14551  SOLID278      0.359   0.000025
             29     14522  SOLID278      0.125   0.000009
             30     14410  SOLID278      0.344   0.000024
             31     14341  SOLID278      0.266   0.000019
             32     14751  SOLID278      0.375   0.000025
             33     16247  SOLID278      0.422   0.000026
             34     15000  SOLID278      0.188   0.000013
             35     15073  SOLID278      0.375   0.000025
             36     14770  SOLID278      0.359   0.000024
             37     14501  SOLID278      0.344   0.000024
             38  10560254  SOLID278    231.469   0.000022
             39  11490626  SOLID278    254.844   0.000022
             40  10953311  SOLID278    236.781   0.000022
             41    451565  SOLID278     10.219   0.000023
             42      4730  SOLID278      0.094   0.000020
             43      4701  SOLID278      0.078   0.000017
             44      4715  SOLID278      0.125   0.000027
             45      4783  SOLID278      0.094   0.000020
             46      4766  SOLID278      0.203   0.000043
             47      4892  SOLID278      0.109   0.000022
             48      4846  SOLID278      0.031   0.000006
             49      4862  SOLID278      0.188   0.000039
             50      4701  SOLID278      0.141   0.000030
             51      4731  SOLID278      0.125   0.000026
             52      4776  SOLID278      0.094   0.000020
             53      4688  SOLID278      0.094   0.000020
             54      4663  SOLID278      0.141   0.000030
             55      4664  SOLID278      0.125   0.000027
             56      4650  SOLID278      0.078   0.000017
             57      4793  SOLID278      0.016   0.000003
             58      4753  SOLID278      0.109   0.000023
             59      4900  SOLID278      0.078   0.000016
             60      4852  SOLID278      0.062   0.000013
             61      4720  SOLID278      0.094   0.000020
             62      4688  SOLID278      0.156   0.000033
             63      4760  SOLID278      0.094   0.000020
             64      4762  SOLID278      0.062   0.000013
             65      4559  SOLID278      0.109   0.000024
             66      4667  SOLID278      0.047   0.000010
             67      4747  SOLID278      0.109   0.000023
             68      4957  SOLID278      0.062   0.000013
             69      4828  SOLID278      0.062   0.000013
             70      4832  SOLID278      0.109   0.000023
             71      4742  SOLID278      0.031   0.000007
             72      4831  SOLID278      0.156   0.000032
             73      4866  SOLID278      0.109   0.000022
             74      4692  SOLID278      0.156   0.000033
             75      4634  SOLID278      0.062   0.000013
             76      4834  SOLID278      0.141   0.000029
             77      4698  SOLID278      0.141   0.000030
             78      4724  SOLID278      0.062   0.000013
             79      4675  SOLID278      0.141   0.000030
             80      4748  SOLID278      0.094   0.000020
             81      4673  SOLID278      0.125   0.000027
             82      4944  SOLID278      0.094   0.000019
             83      4747  SOLID278      0.094   0.000020
             84      4749  SOLID278      0.125   0.000026
             85      4776  SOLID278      0.141   0.000029
             86      4824  SOLID278      0.125   0.000026
             87      8906  SOLID278      0.203   0.000023
             88      8909  SOLID278      0.172   0.000019
             89      8977  SOLID278      0.141   0.000016
             90      9003  SOLID278      0.188   0.000021
             91      9137  SOLID278      0.203   0.000022
             92      9020  SOLID278      0.203   0.000023
             93      8868  SOLID278      0.188   0.000021
             94      8937  SOLID278      0.156   0.000017
             95      8819  SOLID278      0.188   0.000021
             96      8987  SOLID278      0.156   0.000017
             97      8724  SOLID278      0.109   0.000013
             98      9003  SOLID278      0.141   0.000016
             99      9085  SOLID278      0.188   0.000021
            100      9010  SOLID278      0.312   0.000035
            101      8953  SOLID278      0.172   0.000019
            102      9035  SOLID278      0.141   0.000016
            103      8946  SOLID278      0.203   0.000023
            104      9042  SOLID278      0.094   0.000010
            105      9043  SOLID278      0.203   0.000022
            106      8869  SOLID278      0.219   0.000025
            107      8879  SOLID278      0.297   0.000033
            108      8689  SOLID278      0.203   0.000023
            109      8990  SOLID278      0.281   0.000031
            110      8780  SOLID278      0.219   0.000025
            111      9027  SOLID278      0.188   0.000021
            112      8879  SOLID278      0.141   0.000016
            113      8818  SOLID278      0.125   0.000014
            114      8862  SOLID278      0.266   0.000030
            115      9001  SOLID278      0.234   0.000026
            116      9065  SOLID278      0.172   0.000019
            117      9043  SOLID278      0.141   0.000016
            118      8981  SOLID278      0.203   0.000023
            119     62164  SOLID278      1.656   0.000027
            120     61883  SOLID278      1.453   0.000023
            121     61652  SOLID278      1.359   0.000022
            122     61213  SOLID278      1.281   0.000021
            123     61582  SOLID278      1.484   0.000024
            124     61727  SOLID278      1.547   0.000025
            125     61762  SOLID278      1.141   0.000018
            126     61414  SOLID278      1.344   0.000022
            127     62084  SOLID278      1.344   0.000022
            128     61572  SOLID278      1.625   0.000026
            129     61335  SOLID278      1.500   0.000024
            130     61737  SOLID278      1.703   0.000028
            131     61601  SOLID278      1.188   0.000019
            132     61255  SOLID278      1.594   0.000026
            133     61945  SOLID278      1.031   0.000017
            134     61259  SOLID278      1.094   0.000018
            135     61851  SOLID278      1.500   0.000024
            136     61888  SOLID278      1.438   0.000023
            137     62166  SOLID278      1.344   0.000022
            138     61809  SOLID278      1.594   0.000026
            139     62359  SOLID278      1.266   0.000020
            140     61333  SOLID278      1.219   0.000020
            141     61505  SOLID278      1.438   0.000023
            142     61932  SOLID278      1.469   0.000024
            143     61816  SOLID278      1.188   0.000019
            144     61664  SOLID278      0.969   0.000016
            145     61854  SOLID278      0.984   0.000016
            146     61241  SOLID278      1.703   0.000028
            147     61765  SOLID278      1.219   0.000020
            148     61530  SOLID278      0.969   0.000016
            149     62233  SOLID278      1.062   0.000017
            150     61926  SOLID278      1.266   0.000020
            151     12339  SOLID278      0.188   0.000015
            152      9355  SOLID278      0.188   0.000020
            153      2694  SOLID278      0.016   0.000006
            154      2690  SOLID278      0.047   0.000017
            155     33127  SOLID278      0.797   0.000024
            156     23026  SOLID278      0.359   0.000016
            157     88776  SOLID278      1.641   0.000018
            158     70195  SOLID278      1.031   0.000015
            159     38585  SOLID278      0.969   0.000025
            160     23215  SOLID278      0.594   0.000026
            161     56461  SOLID278      1.516   0.000027
            162     37980  SOLID278      0.797   0.000021
            163     23356  SOLID278      0.547   0.000023
            164     86323  SOLID278      1.812   0.000021
            165     42229  SOLID278      0.672   0.000016
            166     39173  SOLID278      0.859   0.000022
            167     43878  SOLID278      0.922   0.000021
            168     38288  SOLID278      0.875   0.000023
            169     43902  SOLID278      0.688   0.000016
            170     39545  SOLID278      0.656   0.000017
            171     23189  SOLID278      0.406   0.000018
            172     44840  SOLID278      1.047   0.000023
            173     35906  SOLID278      0.844   0.000023
            174     35137  SOLID278      0.938   0.000027
            175     44681  SOLID278      1.000   0.000022
            176     54843  SOLID278      1.562   0.000028
            177     68329  SOLID278      1.719   0.000025
            178     50393  SOLID278      1.344   0.000027
            179     23325  SOLID278      0.391   0.000017
            180     39644  SOLID278      1.250   0.000032
            181     43731  SOLID278      0.906   0.000021
            182     73961  SOLID278      1.703   0.000023
            183     43905  SOLID278      1.141   0.000026
            184     37812  SOLID278      0.938   0.000025
            185     54102  SOLID278      0.875   0.000016
            186     38639  SOLID278      0.812   0.000021
            187     11138  SOLID278      0.312   0.000028
            188      1229  SOLID278      0.047   0.000038
            189     10984  SOLID278      0.156   0.000014
            190      1159  SOLID278      0.016   0.000013
            191     10924  SOLID278      0.234   0.000021
            192      3054  SOLID278      0.000   0.000000
            193     79821  SOLID278      1.922   0.000024
            194     20720  SOLID278      0.406   0.000020
            195    281098  SOLID278      4.766   0.000017
            196     13736  SOLID278      0.375   0.000027
            197     37683  SOLID278      1.141   0.000030
            198       842  SOLID278      0.031   0.000037
            199       947  SOLID278      0.000   0.000000
            200      3797  SOLID278      0.094   0.000025
            201    558482  SOLID278     15.422   0.000028
            202     18442  SOLID278      0.359   0.000019
            203     13262  SOLID278      0.484   0.000037
            204     17333  SOLID278      0.562   0.000032
            205      3668  SOLID278      0.141   0.000038
            206     18142  SOLID278      0.297   0.000016
            207     13590  SOLID278      0.297   0.000022
            208     38209  SOLID278      0.750   0.000020
            209      6633  SOLID278      0.203   0.000031
            210      6559  SOLID278      0.109   0.000017
            211      2025  SOLID278      0.047   0.000023
            212       464  SOLID278      0.016   0.000034
            213       478  SOLID278      0.016   0.000033
            214       485  SOLID278      0.000   0.000000
            215       466  SOLID278      0.000   0.000000
            216     29328  SOLID278      0.562   0.000019
            217     15657  SOLID278      0.281   0.000018
            218     10966  SOLID278      0.344   0.000031
            219     16005  SOLID278      0.234   0.000015
            220     18399  SOLID278      0.250   0.000014
            221     15724  SOLID278      0.250   0.000016
            222     17254  SOLID278      0.312   0.000018
            223     18415  SOLID278      0.312   0.000017
            224     16805  SOLID278      0.203   0.000012
            225     17270  SOLID278      0.297   0.000017
            226     13260  SOLID278      0.188   0.000014
            227      7382  SOLID278      0.203   0.000028
            228     17399  SOLID278      0.297   0.000017
            229     17383  SOLID278      0.484   0.000028
            230     17179  SOLID278      0.469   0.000027
            231     17453  SOLID278      0.500   0.000029
            232     23010  SOLID278      0.516   0.000022
            233     17759  SOLID278      0.391   0.000022
            234     17962  SOLID278      0.453   0.000025
            235     17186  SOLID278      0.469   0.000027
            236     17545  SOLID278      0.469   0.000027
            237     57602  SOLID278      1.000   0.000017
            238     17136  SOLID278      0.281   0.000016
            239     17352  SOLID278      0.406   0.000023
            240     33069  SOLID278      0.812   0.000025
            241       454  SOLID278      0.000   0.000000
            242       465  SOLID278      0.016   0.000034
            243       441  SOLID278      0.000   0.000000
            244       459  SOLID278      0.016   0.000034
            245     29259  SOLID278      0.422   0.000014
            246    963055  SOLID278     16.688   0.000017
            247   1051290  SOLID278     23.016   0.000022
            248    981550  SOLID278     21.375   0.000022
            249    235913  SOLID278      4.422   0.000019
            250    240324  SOLID278      4.406   0.000018
            251    240728  SOLID278      4.625   0.000019
            252    235055  SOLID278      4.484   0.000019
            253    240292  SOLID278      4.109   0.000017
            254    240246  SOLID278      4.297   0.000018
            255    235717  SOLID278      4.453   0.000019
            256    241102  SOLID278      4.344   0.000018
            257     98598  SOLID278      2.016   0.000020
            258     96386  SOLID278      2.094   0.000022
            259     96705  SOLID278      1.938   0.000020
            260    100568  SOLID278      2.281   0.000023
            261     94999  SOLID278      2.281   0.000024
            262     97352  SOLID278      1.969   0.000020
            263     95491  SOLID278      2.453   0.000026
            264     95086  SOLID278      2.031   0.000021
            265     99943  SOLID278      3.000   0.000030
            266     95150  SOLID278      2.281   0.000024
            267     96835  SOLID278      2.141   0.000022
            268     98456  SOLID278      2.109   0.000021
            269     94499  SOLID278      2.203   0.000023
            270     97518  SOLID278      2.203   0.000023
            271     95302  SOLID278      2.562   0.000027
            272     95607  SOLID278      2.688   0.000028
            273     96876  SOLID278      1.859   0.000019
            274     98118  SOLID278      1.531   0.000016
            275     95651  SOLID278      1.953   0.000020
            276     98480  SOLID278      1.844   0.000019
            277     96130  SOLID278      1.844   0.000019
            278     95766  SOLID278      1.953   0.000020
            279     95204  SOLID278      1.688   0.000018
            280     96662  SOLID278      1.953   0.000020
            281    519817  SOLID278      9.203   0.000018
            282    525352  SOLID278     13.500   0.000026
            283    525754  SOLID278     13.562   0.000026
            284    750716  SOLID278     17.500   0.000023
            285     16176  SOLID278      0.453   0.000028
            286     12421  SOLID278      0.125   0.000010
            287     12778  SOLID278      0.312   0.000024
            288   1052827  SOLID278     19.797   0.000019
            289    968666  SOLID278     23.750   0.000025
            290   1051895  SOLID278     23.125   0.000022
            291    966683  SOLID278     16.609   0.000017
            292    972072  SOLID278     26.766   0.000028
            293   1057591  SOLID278     23.953   0.000023
            294    978226  SOLID278     17.281   0.000018
            295   1054475  SOLID278     25.719   0.000024
            296    969735  SOLID278     20.703   0.000021
            297   1053586  SOLID278     18.953   0.000018
            298    979897  SOLID278     24.938   0.000025
            299   1055486  SOLID278     22.938   0.000022
            300   1053331  SOLID278     19.172   0.000018
            301    966628  SOLID278     24.344   0.000025
            302    962366  SOLID278     21.719   0.000023
            303    979412  SOLID278     26.500   0.000027
            304    976938  SOLID278     22.531   0.000023
            305    975555  SOLID278     21.500   0.000022
            306    976304  SOLID278     17.797   0.000018
            307   1046396  SOLID278     27.828   0.000027
            308    975946  SOLID278     20.484   0.000021
            309    240759  SOLID278      6.469   0.000027
            310    236358  SOLID278      5.594   0.000024
            311    241634  SOLID278      6.250   0.000026
            312    240687  SOLID278      6.234   0.000026
            313    238658  SOLID278      5.797   0.000024
            314    240934  SOLID278      5.734   0.000024
            315    240756  SOLID278      6.438   0.000027
            316    237775  SOLID278      5.719   0.000024
            317    239151  SOLID278      4.906   0.000021
            318    241368  SOLID278      5.297   0.000022
            319    240287  SOLID278      5.172   0.000022
            320    238324  SOLID278      5.031   0.000021
            321    239657  SOLID278      5.047   0.000021
            322    240421  SOLID278      5.188   0.000022
            323    237931  SOLID278      5.250   0.000022
            324    240242  SOLID278      5.406   0.000023
            325     37636  SURF152       0.453   0.000012
            326     37657  SURF152       0.688   0.000018
            327     37650  SURF152       0.734   0.000020
       Time at end of element matrix formulation CP = 3319.5.
           HT FLOW CONVERGENCE VALUE=  0.1275E+11  CRITERION=  0.1275E+08
       *** WARNING ***                         CP =    3638.609   TIME= 20:48:05
       The in-core memory mode has been requested for the Distributed Sparse
       Matrix Solver used by the PCG solver, however there is not enough
       memory to proceed in the in-core memory mode on one or more processes.
        The Distributed Sparse Matrix Solver will automatically switch to the
       out-of-core memory mode and continue computing the solution.
       *** ERROR ***                           CP =    3638.641   TIME= 20:48:05
       used by the PCG solver to proceed using the out-of-core memory mode.
       The total memory required by all processes = 280532 MB.  The total
       physical memory that is available on the system = 235573 MB.  Please
       physical memory.
       Preconditioned conjugate gradient solver error level 9999.  Please send
       the data leading to this operation to your technical support provider,
       as this will allow ANSYS, Inc to improve the program.
       NUMBER OF WARNING MESSAGES ENCOUNTERED=          3
       NUMBER OF ERROR   MESSAGES ENCOUNTERED=          2
       ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
      +--------------------- M A P D L   S T A T I S T I C S ------------------------+
      Release: 2022 R2            Build: 22.2       Update: UP20220516   Platform: WINDOWS x64
      Date Run: 05/15/2023   Time: 20:48     Process ID: 26396
      Operating System: Windows Server 2019  (Build: 17763)
      Processor Model: Intel(R) Xeon(R) Gold 6246R CPU @ 3.40GHz
      Compiler: Intel(R) Fortran Compiler Version 19.0.5  (Build: 20190815)
                Intel(R) C/C++ Compiler Version 19.0.5  (Build: 20190815)
                Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
                BLAS Library supplied by Intel(R) MKL
      Number of machines requested            :    1
      Total number of cores available         :   64
      Number of physical cores available      :   32
      Number of processes requested           :    4
      Number of threads per process requested :    1
      Total number of cores requested         :    4 (Distributed Memory Parallel)
      MPI Type: INTELMPI
      MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
      GPU Acceleration: Not Requested
      Job Name: file0
      Input File: dummy.dat
        Core                Machine Name   Working Directory
           0              br-xlim-calc-3   D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617
           1              br-xlim-calc-3   D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617
           2              br-xlim-calc-3   D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617
           3              br-xlim-calc-3   D:\LUC\VT4x4\VT4x4_RIC\_ProjectScratch\Scr8617
      Latency time from master to core     1 =    4.978 microseconds
      Latency time from master to core     2 =    5.575 microseconds
      Latency time from master to core     3 =    5.530 microseconds
      Communication speed from master to core     1 =  6483.82 MB/sec
      Communication speed from master to core     2 =  4343.69 MB/sec
      Communication speed from master to core     3 =  4309.93 MB/sec
      Total CPU time for main thread                    :     2319.9 seconds
      Total CPU time summed for all threads             :     3677.3 seconds
      Elapsed time spent obtaining a license            :        0.4 seconds
      Elapsed time spent pre-processing model (/PREP7)  :      310.8 seconds
      Elapsed time spent solution - preprocessing       :      521.7 seconds
      Elapsed time spent computing solution             :     1119.5 seconds
      Elapsed time spent solution - postprocessing      :        2.0 seconds
      Elapsed time spent post-processing model (/POST1) :        0.0 seconds
      Equation solver used                              :            PCG (symmetric)
      Sum of memory used on all processes               :      272.0 GB
      Sum of memory allocated on all processes          :      294.1 GB
      Physical memory available                         :        256 GB
      Total amount of I/O written to disk               :        4.0 GB
      Total amount of I/O read from disk                :        2.4 GB
      +------------------ E N D   M A P D L   S T A T I S T I C S -------------------+
       |                               RUN COMPLETED                               |
       |  Ansys MAPDL 2022 R2         Build 22.2         UP20220516    WINDOWS x64 |
       | Database Requested(-db)  1024 MB    Scratch Memory Requested      1024 MB |
       | Maximum Database Used   48794 MB    Maximum Scratch Memory Used  80593 MB |
       |        CP Time      (sec) =       3677.266       Time  =  20:48:51        |
       |        Elapsed Time (sec) =       2389.000       Date  =  05/15/2023      |
       All
    • Nanda
      Hello Luc,
      We would suggest to raise a new discussion instead of posting in old threads. To add to above comments by Gary and Mike, check if your model is properly constrained. And here is a forum discussion link which might help you to solve the issue.
      error (ansys.com)
      Nanda.
Viewing 5 reply threads
  • The topic ‘There is not enough memory for the Distributed Sparse Matrix Solver to proceed using the out-of-core’ is closed to new replies.
