The question of Thermal-electric model
    • q86121032
      I am using the Thermal-electric model for simulation.
      I set one side of the wire to 0V and the other side to 0.05V.
      Why is the voltage result out of the range, and even the 0V end becomes a negative number.
      What does this mean?
    • dlooman
      Are you doing a joule heat analysis or are you specifying the Seebeck material property?  Is this a steady state or transient analysis?  It's not possible for a constrained temperature to change at all, so the result seems very odd.
