October 8, 2025 at 6:26 pm
October 9, 2025 at 11:17 am
Mrunali Barde
Ansys EmployeeHello Frederic,Â
Can you please try this KM and let me know?ÂLink:
https://customer.ansys.com/s/article/Workbench-error-Ans-SceneGraphChart-SceneGraphAddin
https://customer.ansys.com/s/article/Addins-could-not-be-loaded-Ans-SceneGraphChart-SceneGraphAddin
Can you also try to reconfigure/repair Visual C++ dependencies?ÂYou can also reinstall it from 'C:\Program Files\ANSYS Inc\v2xx\prereq'
I hope this helps.Â
Wishes,Â
Mrunali.
October 9, 2025 at 4:35 pm
frederic.hurek
SubscriberHello Mrunali,
I cannot access the links because I am required to create a Customer Support account, and I don't have an account number. I have also tried repairing the Visual C++ dependencies. I have the Ansys Student version, if that helps.
October 9, 2025 at 5:02 pm
Mrunali Barde
Ansys EmployeeCan you please try the below suggestion and let me know?
Logs indicate that
Qt5Core.dllis being loaded fromC:/Windows/System32. The screenshot suggests thatSystem32contains a large portion of an older or incompatible Qt installation. SinceSystem32is searched before entries in thePATH, the application loads the incorrect Qt library, causing it to failÂÂ
Identify the conflicting files
Open
C:/Windows/System32and locate all files beginning withQt5.Note: There may also be some files starting with lowercase
q(e.g.,qsomething.dll)—review them carefully.
Move or back up the files
Move these
Qt5*files (and potentially conflictingq*files) to a backup directory outsideSystem32.Do not delete them immediately—keep them in case another application requires them.
Restart and retest
Restart your system to ensure changes take effect.
Run the application again and confirm if the issue is resolved.
Caution:
Only remove Qt-related files. Deleting unrelated system files fromSystem32can cause serious OS problems.Â
October 17, 2025 at 12:18 pm
prajyotpatil076
SubscriberI am facing the same issue. there is any way to solve the issue permenantly ??
6535
1311
