Electronics
Electronics
[Test] What is the benefit of Mesh Fusion
    • Yang Zhao
    • AnsysGPT
      Question to Ansys Assistant
      Response from Ansys Assistant
      HFSS Mesh Fusion is a meshing technology that allows you to apply different, locally appropriate meshers to different components in the same electromagnetic model while still solving a single, fully coupled EM problem. This is especially valuable for systems combining ICs, packages, PCBs, connectors, cables and antennas, where feature sizes range from microns to meters, and a single global mesh is either very difficult or inefficient to generate. From Chips to Ships, Solve Them All With HFSS
      Compared to traditional global meshing, Mesh Fusion provides several key benefits in Ansys workflows: it can successfully mesh systems with large variations in length scale by meshing bodies separately yet enforcing conformal meshes at contact interfaces (for example, a small 3D antenna on an aircraft or PCB), it lets you choose different meshers per component (such as Tau, Phi or Classic) so each region uses the most suitable algorithm, and it applies mesh tolerance locally based on component size rather than the overall system, which improves mesh quality and robustness. It also accelerates setup and studies: multiple identical components are meshed only once and reused, placement changes of components do not require re‑meshing (only the final adaptive mesh is reused), and different meshing technologies can run in parallel on HPC resources, leading to substantial meshing time reductions (often several‑fold) while maintaining “gold‑standard” HFSS accuracy and consistent S‑parameter and field results. Mesh Fusion Benefits in HFSS Simulation Mesh Fusion in HFSS for Multi-Scale PCB Simulation From Chips to Ships, Solve Them All With HFSS hfss mesh fusion technology [overview] Advances in Domain Decomposition Methods for Electromagnetics Ansys Signal & Power Integrity Updates 2022 R1 Mesh Fusion and Component Meshing in HFSS What's New in High Frequency Electronics | Ansys 2025 R1
      Common use cases include full-system EM simulations of drones or vehicles containing ICs, packages, PCBs, connectors, cables and multiple antennas; co‑site interference problems with several antennas on a single platform (such as an aircraft); and large electronics like touchscreen panels in EMI chambers, where different subassemblies require different meshing strategies but must be solved together for accurate coupling and emissions prediction. hfss mesh fusion technology [overview]
      Would you like a concise, step‑by‑step outline of how you would typically enable and configure Mesh Fusion in an HFSS project for one of these system‑level scenarios?
