February 22, 2023 at 2:58 amHyeongjin KimSubscriber
Thx for your comment
February 22, 2023 at 7:19 amClaudio PedrazziSubscriber
I will answer only to a part of your question. Be careful with the element axis 11, 22, 33. Look at the element help to see how they are oriented.
Also, you can let Workbench show you the element orientations, you have under the “results” also the possibility to create a plot with the nodal or the element coordinate systems. It is a tricky thing using those (11,22…) because it all depends on their orientation. Even for simple geometries, they are not necessarily well aligned “consistently” in one logical direction.
I advise defining your own coordinate systems, for example in your geometry possibly a cylindrical coordinate system will certainly help for some regions.
- The topic ‘Tensile or compression stress and bending stress each face. local element direct’ is closed to new replies.
- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to apply Compression-only Support?
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
1216
543
523
225
209
