February 5, 2024 at 4:42 am
DRD08
SubscriberHi, I know this is probably a dumb question but I'm just starting to get into CFD using ANSYS FLUENT.
So if I wanted to calculate the drag force on a ship hull, an aircraft, or any body moving through fluid and decide to solve it using symmetry (splitting the domain in half through the centre) do I need to multiply the results by 2? This is if I put a drag force monitor on the object wall.
ÂÂ2 -
February 5, 2024 at 11:46 am
Forum ModeratorForce will be on what you have in the model, so for the whole hull you'll need to double the value. However if you're using coefficients, they're defined with an area in the equations, so you need to check what area you're using.Â
February 19, 2024 at 9:14 am
DRD08
SubscriberOh ok, thanks! I'll give it a try.
- The topic ‘Symmetry in ANSYS FLUENT’ is closed to new replies.
