July 22, 2024 at 8:10 pm
Zwernjayden
SubscriberWhat is the difference? And which should I use for a traditional rocket injector
July 23, 2024 at 8:58 am
Forum ModeratorOne adds the particles from the surface facets and you define the releases diameter(s) the other uses a built in model to determine diameter distribution. They're all explained in the User's Guide under DPM Injections (Initial conditions).Â
As rockets have many "best" designs I can't really comment on that. You know what you're modelling, so what best suits your application?Â
July 23, 2024 at 4:14 pm
Zwernjayden
SubscriberI'm going to assume plain oriface then because I am more concerned about uniform mixing and combustion. If my fuel and oxidizer are both injected using dpm, do I need a traditional pressure or mass flow inlet? Or does the injection take its place?
July 24, 2024 at 12:30 pm
Forum ModeratorThe injection will add the material. You'll just need to evaporate the droplets to have combustion so initial conditions will need selecting with more care.Â
- The topic ‘Surface injection vs plain orifice atomizer’ is closed to new replies.
