February 2, 2026 at 1:56 pm
Ikram.MARZOUKI
SubscriberHello everyone,
I am working on a three-point bending simulation on a composite sandwich structure with a NIDA core in ANSYS Mechanical.
In my model, I apply a Remote Displacement on the upper cylinder, with a prescribed translation in the Z direction. After running the simulation, I evaluate the failure criteria of the composite facesheets.
What I would like to achieve is the following:
instead of prescribing a final displacement value and checking failure afterward, I want the simulation to automatically stop at the displacement where the first failure criterion is reached (damage initiation or rupture).In other words, I would like the solver to stop when a failure index reaches 1, and to directly obtain the corresponding displacement value.
Is there a way in ANSYS Mechanical to:
stop the analysis based on a composite failure criterion, or
link the stopping condition to damage initiation, material failure, or a user-defined result?
Any guidance, examples, or recommended approaches (e.g. nonlinear analysis, APDL commands, user-defined results, or damage models) would be greatly appreciated.
Thank you very much for your help.
Best regards,
March 3, 2026 at 1:31 pm
Raman Babu
Ansys EmployeeThe NLHIST command can be used to terminate the solution once the selected result item attains a specific value.Â
The approach can be used within Mechanical through a command snippet.
- Stopping simulation automatically at composite failure based on displacement
- QuartodiLitro Motostudent | Fork feet analysis and optimization
- E-Racing Bergamo | Chassi’s torsional deformation
- Tress structural´s simulation using carbon fiber tubes
- CFD Simulation (Fluent) on Brazil FSAE CAR (FORMULA UFPB)
- Mission to Launch: Precision Engineering at UPC Space Program with Ansys Simulat
- Transmission System Development (Structural Simulation) Protto UFSC Motorsport
5989
1307
