July 5, 2021 at 5:23 pmjohn.x.juveliSubscriber
Hi all,
I am attempting to do a PCM for melting and solidifcation of a eutectic tin lead solder, and am curious as to my material property accuracy.
My understanding is that the standard state enthalpy is your molecular weight [kg/kmol] multiplied by the latent heat [J/kg] to get the appropriate enthalpy [J/kgmol]. Is this accurate here?
Additionally, I have the MW of 63Sn-37Pb as ~320 kg/kmol by simply adding the two atomic weights of both Tin (118.71 ) and Lead (207.2). Is this a good ballpark estimation? Am I missing anything critical here?
Regards.
July 8, 2021 at 3:09 pm1shanAnsys EmployeeChemistry is not my strong point but from whatever I remember, I think you need to multiply the mole fraction with the respective molecular weight and then add for each component. So 0.63*118 + 0.37*207 = 150 should be the average molar mass of the alloy.
Regards Ishan.
Viewing 1 reply thread- The topic ‘Standard State Enthalpy of 63Sn-37Pb’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Chemkin requires HPC
- Calculate heating of an assembly for a given ambient temperature?
- Press hardening characterization
- ACP PRE problem
- Explicit Dynamics Material properties
- Documentation of the kinetics of the reaction of methylamine with NO
- Temperature-dependent viscosity model used in FLUENT flow analysis
- orthotropic material proprierties give me “missing” data, what could it be?
- Get ultimate strength value from simulation
Top Contributors-
1341
591
584
525
366
