June 9, 2023 at 8:06 pm
daniel.eichorn
SubscriberI am running Random Vibration on "Enterprise" version and get this:
*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 0.203 Â TIME= 14:54:00
 The option of SPECTR on the ANTYPE command is either not available for Â
 this version of Ansys or the appropriate product was not selected for  Â
 this session.                              Â
 Contact your Ansys support person for more information.What does this mean? No license?
June 12, 2023 at 12:00 pm
Aniket Chavan
Forum Moderator -
June 12, 2023 at 1:15 pm
daniel.eichorn
SubscriberI reran the analysis this morning and there were no issues. I cannot explain why, nothing changed except the time at which I ran it.
I then added "Fatigue Tool" - both "Life" and "Damage". Updating produces this new error: "To proceed with Fatigue analysis, 'Calculate Velocity' and 'Calculate Acceleration' in Output Controls must be set to Yes."
I set these to "Yes" in Options>Analysis Settings and Solution but the error persists.
June 12, 2023 at 1:20 pm
daniel.eichorn
SubscriberDiscovered that Calculate Acceleration/Calculate Velocity are under Random Vibration Analysis Settings and don't seem related to the same function in Options... Analysis ran.
June 12, 2023 at 2:46 pm
daniel.eichorn
SubscriberInitial issue happened again...
@Aniket - per your request:
 2023 R1Â
 Point Releases and Patches installed:  Â
 ANSYS, Inc. License Manager 2023 R1Â
 Discovery 2023 R1  Â
 SpaceClaim 2023 R1 Â
 Ansys Sherlock 2023 R1 Â
 Autodyn 2023 R1Â
 LS-DYNA 2023 R1Â
 CFD-Post only 2023 R1  Â
 CFX (includes CFD-Post) 2023 R1Â
 Chemkin 2023 R1Â
 EnSight 2023 R1Â
 FENSAP-ICE 2023 R1 Â
 Fluent (includes CFD-Post) 2023 R1 Â
 Polyflow (includes CFD-Post) 2023 R1
 Forte (includes EnSight) 2023 R1
 TurboGrid 2023 R1  Â
 ICEM CFD 2023 R1
 Motion 2023 R1 Â
 Aqwa 2023 R1
 Speos 2023 R1  Â
 Speos HPC 2023 R1  Â
 Speos for NX 2023 R1
 optiSLang 2023 R1  Â
 Additive 2023 R1
 Customization Files for User Programmable Features 2023 R1 Â
 Mechanical Products 2023 R1Â
 Material Calibration App 2023 R1
 Icepak (includes CFD-Post) 2023 R1 Â
 Remote Solve Manager Standalone Services 2023 R1
 Ansys Sound - SAS 2023 R1  Â
 Viewer 2023 R1 Â
 ACIS Geometry Interface 2023 R1Â
 AutoCAD Geometry Interface 2023 R1 Â
 Catia, Version 4 Geometry Interface 2023 R1Â
 Catia, Version 5 Geometry Interface 2023 R1Â
 Catia, Version 6 Geometry Interface 2023 R1Â
 Creo Elements/Direct Modeling Geometry Interface 2023 R1
 Creo Parametric Geometry Interface 2023 R1 Â
 Inventor Geometry Interface 2023 R1Â
 JTOpen Geometry Interface 2023 R1  Â
 NX Geometry Interface 2023 R1  Â
 Parasolid Geometry Interface  2023 R1  Â
 Solid Edge Geometry Interface 2023 R1  Â
 SOLIDWORKS Geometry Interface 2023 R1  Â
     *****  MAPDL COMMAND LINE ARGUMENTS  *****
 BATCH MODE REQUESTED (-b)   = NOLIST
 INPUT FILE COPY MODE (-c)   = COPY
 DISTRIBUTED MEMORY PARALLEL REQUESTED
    4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
  TOTAL OF   4 CORES REQUESTED
 INPUT FILE NAME        = C:\Users\user\Downloads\_ProjectScratch\Scr531A\dummy.dat
 OUTPUT FILE NAME       = C:\Users\user\Downloads\_ProjectScratch\Scr531A\solve.out
 START-UP FILE MODE      = NOREAD
 STOP FILE MODE        = NOREAD
 RELEASE= 2023 R1        BUILD= 23.1    UP20221128  VERSION=WINDOWS x64Â
 CURRENT JOBNAME=file0  10:30:51  JUN 12, 2023 CP=    0.141
 PARAMETER _DS_PROGRESS =   999.0000000  Â
 /INPUT FILE= ds.dat  LINE=    0
 *** NOTE ***               CP =    0.266  TIME= 10:30:51
 The /CONFIG,NOELDB command is not valid in a distributed memory     Â
 parallel solution.  Command is ignored.                 Â
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  10.5141667  Â
 *********** Resuming The ANSYS db File from Modal Solution ***********
 RESUME ANSYS DATA FROM FILE NAME=C:\Users\user\Downloads\Busbar_files\dp0\SYS-1\MECH\file.db        Â
 *** MAPDL GLOBAL STATUS ***Â
 TITLE = Busbar--Modal (A5)                         Â
 ANALYSIS TYPE =  MODAL        Â
     1 ELEM TYPES DEFINED   MAX ELEM TYPE NUMBER =       1
   74795 ELEMENTS DEFINED    MAX ELEMENT NUMBER =      74795
  127605 NODES DEFINED     MAX NODE NUMBER =       127605
     1 MATERIALS DEFINED   MAX MATERIAL NUMBER =        1
     0 REAL CONSTS DEFINED  MAX REAL CONST NUMBER =       0
     0 SECTIONS DEFINED    MAX SECTION NUMBER =        0
     0 COORD SYS DEFINED   MAX COORD SYS NUMBER =       0
 ACTIVE COORDINATE SYSTEM       =      0  (CARTESIAN)
 NUMBER OF DEFINED NODAL CONSTRAINTS  =    2106
 NUMBER OF DEFINED NODAL LOADS     =      0
 NUMBER OF DEFINED COMPONENTS     =      3
 NUMBER OF DEFINED ELEM SURFACE LOADS =      0
 NUMBER OF DEFINED ELEM BODY LOADS   =      0
 NUMBER OF DEFINED NODE BODY FORCES  =      0
 CURRENT LOAD CASE =    0 OF    0
 LOAD SET  =    1
 SUBSTEP   =    6
 TIME/FREQ  =   0.0000  Â
 INITIAL JOBNAME = file
 CURRENT JOBNAME = file
 TITLE=Â
 Busbar--Random Vibration (B5)                       Â
 ACT Extensions:
   LSDYNA, 2023.1
   5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
 /COM,   ANSYSMotion, 2023.1
   20180725-3f81-49eb-9f31-41364844c769, wbex
 *****  MAPDL SOLUTION ROUTINE  *****
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR_PSD
 TYPE=STRI  DIMENSIONS=    248     1     1
 PARAMETER _WB_PROJECTSCRATCH_DIR_PSD(1) = C:\Users\user\Downloads\_ProjectScratch\Scr531A\
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR_PSD
 PARAMETER _WB_SOLVERFILES_DIR_PSD(1) = C:\Users\user\Downloads\Busbar_files\dp0\SYS\MECH\
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR_PSD
 PARAMETER _WB_USERFILES_DIR_PSD(1) = C:\Users\user\Downloads\Busbar_files\user_files\
 Graphical-Solution-Tracking set to ON
 For /MENU,ON or /MENU,GRPH operations, GST ToFile option is ON Â
 FINISH SOLUTION PROCESSING
 ***** ROUTINE COMPLETED *****  CP =     0.422
 *GET  _NUMNODE  FROM  NODE  ITEM=COUN    VALUE=  127605.000   Â
 *GET  _NUMELEM  FROM  ELEM  ITEM=COUN      VALUE=  74795.0000  Â
 *GET  _MAXELEMNUM  FROM  ELEM  ITEM=NUM  MAX    VALUE=  74795.0000  Â
 *GET  _MAXNODENUM  FROM  NODE  ITEM=NUM  MAX  VALUE=  127605.000   Â
 *GET  _MAXELEMTYPE  FROM  ETYP  ITEM=NUM  MAX  VALUE=  1.00000000  Â
 *GET  _MAXREALCONST  FROM  RCON  ITEM=NUM  MAX  VALUE= 0.788860905E-30
 --- Number of total nodes = 127605
 --- Number of contact elements = 0
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 74795
 --- Number of condensed parts = 0
 --- Number of total elements = 74795
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  10.5141667  Â
 *** ERROR ***              CP =    0.438  TIME= 10:30:51
 this session.                              Â
 Contact your Ansys support person for more information.        Â
 NUMBER OF WARNING MESSAGES ENCOUNTERED=      0
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=      1
+--------------------- M A P D L Â S T A T I S T I C S ------------------------+
Release: 2023 R1 Â Â Â Â Â Â Build: 23.1 Â Â Â Update: UP20221128 Â Platform: WINDOWS x64Â
Date Run: 06/12/2023 Â Time: 10:30 Â Â Process ID: 41924
Operating System: Windows 10 Â (Build: 19043)
Processor Model: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
Compiler: Intel(R) Fortran Compiler Version 19.0.5 Â (Build: 20190815)
     Intel(R) C/C++ Compiler Version 19.0.5  (Build: 20190815)
     Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
     BLAS Library supplied by Intel(R) MKL
Number of machines requested       :   1
Total number of cores available     :  12
Number of physical cores available    :   6
Number of processes requested      :   4
Number of threads per process requested : Â Â 1
Total number of cores requested     :   4 (Distributed Memory Parallel)        Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
 Core         Machine Name  Working Directory
   0          MCHNNAME  C:\Users\user\Downloads\_ProjectScratch\Scr531A
   1          MCHNNAME  C:\Users\user\Downloads\_ProjectScratch\Scr531A
   2          MCHNNAME  C:\Users\user\Downloads\_ProjectScratch\Scr531A
   3          MCHNNAME  C:\Users\user\Downloads\_ProjectScratch\Scr531A
Latency time from master to core   1 =   4.497 microseconds
Latency time from master to core   2 =   3.795 microseconds
Latency time from master to core   3 =   5.220 microseconds
Communication speed from master to core   1 =  5860.12 MB/sec
Communication speed from master to core   2 =  6472.49 MB/sec
Communication speed from master to core   3 =  6478.15 MB/sec
Total CPU time for main thread           :     0.8 seconds
Total CPU time summed for all threads       :     0.5 seconds
Elapsed time spent obtaining a license       :     0.5 seconds
Elapsed time spent pre-processing model (/PREP7) Â : Â Â Â Â 0.0 seconds
Elapsed time spent solution - preprocessing    :     0.0 seconds
Elapsed time spent computing solution       :     0.0 seconds
Elapsed time spent solution - postprocessing    :     0.0 seconds
Elapsed time spent post-processing model (/POST1) : Â Â Â Â 0.0 seconds
Sum of memory used on all processes        :    97.0 MB
Sum of memory allocated on all processes      :   5184.0 MB
Physical memory available             :     64 GB
Total amount of I/O written to disk        :     0.0 GB
Total amount of I/O read from disk         :     0.0 GB
+------------------ E N D Â M A P D L Â S T A T I S T I C S -------------------+
 |                RUN COMPLETED                 |
 |  Ansys MAPDL 2023 R1     Build 23.1     UP20221128   WINDOWS x64  |
 |  Database Requested(-db)   1024 MB   Scratch Memory Requested  1024 MB |
 |  Max Database Used(Master)   79 MB   Max Scratch Used(Master)    3 MB |
 |  Max Database Used(Workers)   1 MB   Max Scratch Used(Workers)   4 MB |
 |  Sum Database Used(All)     82 MB   Sum Scratch Used(All)     15 MB |
 |     CP Time    (sec) =      0.500    Time  =  10:30:52      |
 |     Elapsed Time (sec) =      3.000    Date  =  06/12/2023     |
 AllÂ-
September 25, 2023 at 10:57 am
Aniket Chavan
Forum ModeratorThanks for adding this info, Daniel, in addition to the output that you have pasted, first line of the solver output (before legal notice) will indicate the license used to solve it:
What does it show?
-Aniket
September 22, 2023 at 8:00 pm
Mateus Cornelsen
SubscriberHi,
I ran into the same issue doing a very similar analysis. This error is due to the license in use not suporting the random vibration analysis, try switchting to a licensing level premium or enterprise. If you are using a student license it should have run, please check with support then.
You can check more about this on the ANTYPE command section on the Ansys Help
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/ans_cmd/Hlp_C_ANTYPE.html
- The topic ‘SPECTR on the ANTYPE command not available’ is closed to new replies.
