July 9, 2024 at 7:24 pm
jonathanemmanuel.salgado
SubscriberHi , Currently I´m facing issues trying to make changes to the geometry using workbench.
Spaceclaim is not working properly.
When looking at the CAD configuration manager, the error that appears is the following.SC Workbench PlugIn ..... Not Configured
Does anybody know how to install this plug in or where can i found it?
August 20, 2024 at 10:58 am
Rajeshwari Jadhav
Forum ModeratorHi Jonathan,
Go to Start Menu Expand Ansys 202x Rx folder--> Right-click on CAD Configuration Manager 202x Rx and run as administrator--> Check on SpaceClaim (all users) and click Next--> Configure Selected CAD Interface.
Run the ProductConfig.exe from C:\Program Files\Ansys Inc\v2xx and configure the application again, by right-clicking the productconfig.exe file and select "Run as Administrator"> Unconfigure products then configure again by selecting all options. Make sure you run this as administrator and install all the prerequisites.
Let me know if this helps you
5739
