January 30, 2023 at 11:24 pmCH LeeSubscriber
hello, as title the application just instantly shut off when i try to launch it then nothing else happen after, spaceclaim 2022 r2 , already try with run as administrator and reinstallation , please help
January 31, 2023 at 1:27 amAtharv JoshiForum Moderator
Hello CH Lee ,
Can you please try activating the licenses using the command window and then try launching the application?
Please refer Discovery Subscription license - Command line options  for instructions on activating licenses through command line.Â
Let me know if this resolves the issue for you.
Thanks and Regards
January 31, 2023 at 3:26 amGUICADSubscriber
This issue appears with all of our customers.
Are you looking at the problem or will the solution always be to go through a command line ?
Thanks,
January 31, 2023 at 5:37 amAtharv JoshiForum Moderator
Hello CH Lee ,
Can you please share the log files located at ~
/Ansys Inc .  Install.logÂ
Install_licconfig.logÂ
Install.err (if it exists)Â
January 31, 2023 at 10:18 pmCH LeeSubscriber
Atharv Joshi  hello sorry for the late reply ,i would like to thank you for the speedy reply ,the following solution provided using the command line help solve the problem, thank you very much, i have attached the following files and some extra few as requested hope these help. Thanks again!
- The topic ‘spaceclaim 2022 r2 Application not launching’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
1416
599
591
565
366
