November 22, 2020 at 5:50 pmSbspcaSubscriber
I am working on thermal to structural coupled analysis in ANSYS APDL product launcher. But my solution is not converged. Would you please help me?
I am waiting for your answer
Kind Regards...
November 22, 2020 at 7:52 pmSbspcaSubscriberAny ? nNovember 22, 2020 at 8:16 pmpeteroznewmanSubscribernWhat type of coupling are you using? Is there a Thermal model whose results are computed one time to import into the Structural analysis to compute the deformation due to the imported temperature distribution? A one-way coupling? Or is it a two-way coupling where the structural solution is fed back to the thermal model to iterate back and forth?nWhich solution is not converging?nViewing 2 reply threads- The topic ‘Solition is not converged ERROR, ANSYS apdl’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1416
599
591
565
366
