December 7, 2024 at 12:50 pm
hanjt24
SubscriberI have a power chip parallel DBC board assembly module built in SolidWorks, which contains simple wire bonding, and I want to analyze its DC IR drop. Can I use SIWave for this? It seems that the MCAD file exported from SolidWorks and the ECAD file required by SIWave are not compatible.ðŸ˜
December 13, 2024 at 9:09 am
Yang Zhao
Ansys EmployeeHi Hanj,
You are correct. ECAD is more suitable for SIwave. You may consider using Q3D Extractor instead.
Q3D Extractor can load MCAD model and extract RLGC at both DC and AC frequencies. Q3D is widely used in the design of power module products (such as, IGBT and Busbar).
Yang
1885
1404
1303
