TAGGED: 2-way-coupled-fsi, fluent, transient-structural
July 9, 2024 at 7:42 pmAbishek SreenivasanSubscriberHello,My research group is trying to model a two-way Fluid Structure Interaction (FSI) using the Fluent and Transient Structural modules available in the ANSYS Suite. Our simulation times, at the moment, are around a day for a total simulation time of 2 seconds. We'd like to reduce the total computational time from a day to something more manageable and to that end, would like to upgrade our desktop/components of the desktop. This is our current configuration:
- INTEL i9-13900 CPU
- 32 GB DDR5 RAM
- NVIDIA T1000 8 GB GPU
- 1 TB SSD
What would you recommend that we upgrade to see the best return on investment? Additionally, is there a way to make ANSYS use the GPU to solve the simulation that would result in a lower computational time as compared to using the CPU and if so, what GPU would you recommend?Thank you -
July 26, 2024 at 2:05 pmMangeshANSYSAnsys Employee
I hope you are running Ansys 2024 R1 or ideally 2024 R2 now. I am suggesting a two pronged approach to your concerns.
Firstly, opening another thread to focus on the model aspects, physics involved, setup, timestep, which results are being calculated and stored and how often, and importantly the model size and thus computational demands and using
Second - would be how to ensure optimal execution and additional or replacement hardware to speed up the process.
for GPU Acceleration and GPU compute please see see the PDF files linked here named accordingly
https://www.ansys.com/it-solutions/platform-support
- The topic ‘Simulation Time – ANSYS Fluent and Transient Structural’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
565
366
