Simulation of bonding two small polymer plates in ANSYS
    • amahar3
      Hi. I wanted to do a simulation of bonding two small polymer plates in ANSYS by heating the two plates near glass transition temperature and apply pressure from all sides. Also, we need to see if there are air bubbles trapped in the bonded interface. Can we do this simulation in ANSYS? Any guidance on this would be greatly appreciated.Thanks
    • Supreetha J
      Hello Anish,
      Kindly refer to this Forum discussion Simulation of bonding two polymer plates (ansys.com)
      I hope this helps.
      Thank you.
    • amahar3
      Thank you for the suggestion.
  • The topic ‘Simulation of bonding two small polymer plates in ANSYS’ is closed to new replies.
