Electronics
Electronics
Simulation of BLDC motor
    • ranjanpal999
      I am trying to learn simulation of BLDC motor for which I referred the inbuilt model ‘ws-1.aedt’ In the following directory: *Win64ExamplesRMxprtldc
      I have following 2 queries:
      Question 1)
      I used the default values for the simulation and the current waveform is as shown below:
    • Navya Chode
      Hi @ranjanpal999 The example you are using is a BLDC motor and the control type available is only DC or CCC which creates only trapezoidal waveform.
      You can choose assm example instead of bldc .
      In RMXprt assm example double click on Machine control type to AC before analyzing.
      Then you can get (close to) sinusoidal current.
      Regards Navya
    • ranjanpal999
      Thanks a lot for your valuable feedback.
  • The topic ‘Simulation of BLDC motor’ is closed to new replies.
