October 22, 2024 at 9:04 amRobertoSubscriber
Hello I would like the holes as pink regions by default, that is, those preserved during optimization and not the wall that takes me behind.
I attach files and videos, I would like to know if it is possible to eliminate the default protect deph Regards -
October 22, 2024 at 9:20 amDevendra BadgujarForum Moderator
Hello,Â
Let me check and get back to you on this.
DevendraÂ
October 22, 2024 at 9:48 amRobertoSubscriber
Hello Devendra
For now I solved it by setting the default value to 0, and added another one
Regards
October 23, 2024 at 11:52 am
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
591
544
524
366
