November 15, 2024 at 12:21 pmikeya.uriaSubscriber
Hi everyone - hope one of you reading could help me out please,
I need to calculate the shear force that the 18 bolts of a driven wheel (orange in the attached picture) must withstand during acceleration. The orange flywheel has to be accelerated from rest to 100 RPM in 0.4 seconds. I have the following data: the wheel's moment of inertia, the torque applied to the 18 bolts, relevant dimensions, and other necessary parameters. The drive wheel (blue in the picture) is the one transmitting the rotational movement to the driven wheel.
Hope someone can through a little bit of light here! Many thanks in advance,
Ike
November 19, 2024 at 9:35 amErik KostsonAnsys Employee
Hi
We have a set of courses for bolted connections.
It is free also so very good to look at before setting up your model (courses show ways to set up connections):
https://innovationspace.ansys.com/courses/learning-track/pre-loaded-bolted-connections/
All the best
Erik
- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to apply Compression-only Support?
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
1216
543
523
225
209
