Ansys Products
Ansys Products
Server1 cannot be empty or contain special characters
    • jcastel
      error when opening fluent, error references incorrect server info, license client settings app will not let me modify server info.
    • ANSYS_MMadore
      This is only an issue with version 2021R1, with 2021R2 you would be able to change the servername correctly.
      With 2021R1, ror a workaround, they will just need to modify their ansyslmd.ini file manually to put the ÔÇô back in after using the settings to add it without the hyphen.
      Example: in Settings Utility, specify -DESKTOP123
      In ansyslmd.ini ÔÇô modify to:DESKTOP-123
      They may need to save a copy of the ansyslmd.ini to the desktop and then replace the copy in C:\Program Files\Ansys Inc\Shared Files\Licensing to avoid permissions issues.
  • The topic ‘Server1 cannot be empty or contain special characters’ is closed to new replies.
