S809 airfoil meshing error with 2 of the faces
    • omarabs098
      I am having errors meshing two of the faces for the S809 aifoil. In the geometry section you can see to the right of the airfoil the two faces highlighted in green are at the end of the airfoil however when I enter the mesh tab the airfoil seems to cuts into the two faces I created causing errors. How do I fix this?
    • Keyur Kanade
      What version you are using? Try to use 2024R2.
      What is error? Is it 2D? What settings you have used?
      Can you open file in SpaceClaim and then take it to Meshing?
